xr 650 choke plate
5 replies to this topic
  • n2motocrf450
Posted October 30, 2006 - 08:23 AM
What is the issue with being recommended to change the choke plate on these Xr650's, I have a 2004 xr 650r, could anyone please explain or post picture's? Thanks.:mad:
  • pigryder
Posted October 30, 2006 - 08:40 AM
Well they say that the spring and plate, the little flapper on the choke plate come apart and get sucked into the intake. All that is required is a new choke plate like the one from xrs only that doesnt have the spring and flapper, theres just two screws that hold it on. Very easy to replacehttp://www.xrsonly.c...emart&Itemid=77
  • n2motocrf450
Posted October 30, 2006 - 08:52 AM
Thanks for the reply, does this change or cause any problems on initial startup when using the choke, when you replace with aftermarket choke plate? Thanks!
  • HawkGT
Posted October 30, 2006 - 09:05 AM
I justs removed the choke plate flapper--didn't replace it with another unit. The choke still functions.
  • vaughn
Posted October 30, 2006 - 11:29 AM
I have to disagree with the choke still working as before. I removed mine and immediately notice a lack of choke effect. You could move the choke lever from full to mid to off and not tell hardly any running difference at idle. I started much harder also. I think this is dependent on your pilot/fuel screw setting, temperature and altitude as the affect of the choke. For me, I would get the replacement plate from XRs Only.
  • pigryder
Posted October 30, 2006 - 11:31 AM
I agree when I removed my flapper the choke didnt work as before so I bought the aftermarket one and its works as new
Washington
  • Hot  32 replies
  • 4 replies
  • Hot  60 replies
  • 3 replies
