XR600R choke plate, is it really a problem?
5 replies to this topic
  • oldSkewl
Posted October 28, 2006 - 07:50 AM
OK, how many XR600Rs actually swallow their choke plates? Is the problem related to certain years or all XR600Rs? Mine is a 98 I bought used with about 7K miles on it. If it hasn't sucked it down by now will it ever? If I do need it how hard is it to install? How long does it take to do it? I hear the XR's only plate doesn't fit very well and needs to be hand fitted (sanded etc).
Anybody still running stock carbs WITHOUT the plate? You guys me got all parnoid about this issue! Thanks... :mad:
  • frankstr
Posted October 28, 2006 - 08:35 AM
I ran my stock carb without the choke plate...Heard and seen enough
to convince me to remove it....
I now have a Edelbrock on my BRP....:mad:
:mad: :mad:
  • cleonard
Posted October 28, 2006 - 11:15 AM
I have a 93 600. Last year I had the bike apart and I looked at the plate. The flap was hanging by a thread and the rest of the plate had a big crack almost all the way through. My bike has a *lot* more than 7000 miles on it. So yes it is a problem in your future.
I just yanked the plate out completely. I have started the bike down to about 30 degrees by tipping it over so the carb floods. I also have a richer than stock pilot.
  • Jon-D
Posted October 28, 2006 - 02:40 PM
After reading some of the posts, I too took off my choke plate. 93 XR 600, no problems starting it without the plate, stock jetting except the pilot jet which is one step richer.
I did recently switch to an Edelbrock carb which does not have a choke and the bike is still easy to start.
  • rmhrc630
Posted October 28, 2006 - 05:08 PM
eventually they will all swallow their plates.
the stock versions fatigue through general wear and tear.
consider it a consumable (not for your engine!!!)
  • Redlines
Posted October 28, 2006 - 05:38 PM
I have a XR's only choke plate that is like new I will sell you for $20 shipped. You will have to reuse your stock screws because I lost the ones for the XR's only choke plate
