PLEASE help w/ clutch spring...
No replies to this topic
  • mnnthbx
Posted October 27, 2006 - 11:13 AM
I thought I was a good mechanic until today. I have nearly finished converting a 99 YZ 400 into a motard for a friend. All I lack is getting the clutch cable hooked up, but there is so little tension on the shaft (coming out of the left side of the motor) that it won't even pull the clutch lever back out. I can't just twist it around another turn, be cause 1/2 way around it runs out of spring, and coil binds....
This has to be something simple that I'm missing. What is it?
