Engine swap?
5 replies to this topic
  • Mike38
Posted October 25, 2006 - 05:39 PM
Will a 2001 YZ426F engine bolt into a 1999 YZ400F frame? E-Z change, or major project?
THANKS [search not working]
  • cowboyona426
Posted October 25, 2006 - 07:45 PM
As far as I know you should be able to pull that off no problem, but don't quote me on that! :mad:
  • ausgeflippt13
Posted October 25, 2006 - 09:08 PM
my philosophy is that anything's possible, given enough time, creativity, and resources.
That said, the 426 is very similar to the 400 externally (if not identical), so if the motor doesn't bold up directly, it will only require minor modifications to mounting brackets to make it fit.
As far as i'm concerned, it should be fun!!! :mad:
Posted October 26, 2006 - 07:52 AM
I don't know categorically if it will fit or not, but the biggest obstacle in some of these swaps is often the dimensions of the swing arm and pivot. That is, the width of the rear hard point on the engine, and the bolt diameter. YZF's do usually use removable steel inserts at that point, though, and these can often be removed and remade to solve a mismatch within limits.
OTOH, Whole YZ426's are getting less expensive by the day, why not just buy one?
  • Mike38
Posted October 27, 2006 - 03:06 AM
The 400 has been "DTXed" and is raced in flattrack. About $1800 in suspention work, different rims and tires. I figured it would be quickest / cheapest to just drop in another engine. The old 1999 engine is plain wore out.
  • Dano426
Posted October 27, 2006 - 06:37 AM
I have an 01 426 frame, sub frame, air box and swing arm that may help you out with your suspension motor issue.
PM me if you are interested
  • 3 replies
  • 10 replies
  • On January 15, 2017
  • Hot  38 replies
