It's been a while since I posted anything worthwhile so this was long overdue.
Last weekend the kid’s bike was ticking so I figured it was time to check the valves. Seeing as how there is a lot of mystique surrounding valve adjustment I thought I'd take a few pics and post a guide while I was at it.
This was a very simple job. I'd rate it a 4 on a scale of 1 - 10. Nothing too tricky here, but just be sure to check the adjustments carefully and button everything up snugly when you're done.
And as always, I'm not a mechanic or a trainer. Any adjustments you make to your own bike are done with you and you alone being responsible.
That said, let's get on with it...
The first part comes with no pics as you all should be able to do it. Take off both "radiator" guards, the entire airbox, and pull the plug.
When you do that, you're left with this:
I took the liberty of labeling the air screw while I was labeling stuff. It's commonly looked for and I figured the reference would come in handy.
Now look at the side of the motor where the covers are. You'll see two covers that need to be removed:
After you carefully remove the covers with a large regular screwdriver you'll see the next image. Note I say carefully. I almost stripped out the small one covering the timing marks. I ended up taking a hammer and tapping the screwdriver in the edge a few times to loosen it up. After you remove the covers you'll notice the pointer in the small hole, and after you rotate the crankshaft bolt with a 17mm socket counterclockwise a few times you'll see the two marks come up, and go a little further and you'll see the one single mark. that's the one we want to line up with the pointer like this:
Now, you have to be sure that you're on the compression stroke. The way you do this is you wiggle the rocker arms. If both the intake and exhaust arms wiggle you're on the compression stroke. If one or both are really tight you're on the exhaust stroke.
The two tappet covers are removed with a 21mm socket wrench.
Now, let's focus on the intake valve. It's the one on top of the engine beside the intake runner:
The specs call for it to be between .05 and .09mm (or .002 - .0035 inches). I couldn't get the .05 (.002 inch) gauge to slide through it so my valve was too tight. I backed it off so that the .05 (.002 inch) would slide easily and then I realized that without the SST valve adjustment tool I couldn't hold it here it was when I tightened it back up. The way I compensated for this was I loosened it up a little more until the .07 (.0028 inch) fit snugly and with the .07 (.0028 inch) feeler still in there I tightened the locknut back down. As it snugged up it tightened the valve a little more and it ended up being almost a perfect .06 (.0024) which is right in spec.
Here's a pic of the exhaust valve before I checked it:
and a good pic of the 8mm wrench loosening the locknut:
Specs for the exhaust valve are between .08-.12 ( or .031-.047 inches). When I first checked it the .08 (.031 inch) wouldn't slide through. After I backed the adjuster off a little, I got the .08 (.031 inch) to slide in tightly:
As before, I picked a center gauge to tighten it down on. here’s a pic of tightening the locknut with the .10 (.004 inch) gauge inserted:
And that about sums it up...
Put the tappet covers back on, put the plug back in and hook up the wire, put the airbox back on (might as well clean and oil the filter while you have it out), and put the side covers back on and you're done.
See, I told you it was easy...
As always, if there is any bad info, or anything I could have simplified let me know and I'll edit these posts.
