Xr650r White Brothers E2 Jetting
24 replies to this topic
  • Mojave Monster
Posted October 30, 2006 - 09:57 AM
#21
Try this... http://www.xrsonly.c...uemart&Itemid=6
I did my own as most do. Cheap and easy. The reason to open the air box is with a bigger jet you have more gas going in which requires more air to burn.
  • Boston Mangler
Posted October 31, 2006 - 06:10 PM
#22
$10 cheaper and supporting a great guy/racer:
act=viewProd&productId=20' class='bbc_url' title='External link' rel='nofollow external'>http://blaisracingse...od&productId=20
  • dick757
Posted November 01, 2006 - 04:42 PM
#23
Had the same prob
Took the stock filter and screen and put it in a bag and replaced it with the UNI filter, and took the 2 plugs out of the air box and drilled 4 holes in the side panel
Works great now and I have the PC496 pipe
  • Pig_N_CR5hundy
Posted November 04, 2006 - 06:54 PM
#24
Seems like this problem may have to do with the E2 pipe. I had all of the uncorking mods done according to Honda, using an HRC tip, it ran great. When I put the E2 on, it started backfiring and won't idle worth a crap. My plug is choclate brown color. I too am at sea level. Since the E2 is a quiet pipe. it obviously flows less air, I am thinking the jetting needs to be different than the regular "uncorked" bike with HRC tip.................
  • Pig_N_CR5hundy
Posted November 05, 2006 - 07:36 AM
#25
Just updating, looking at the White Bros website, the jetting specs for the E2 says "stock". That is the problem, carving up your side panel will not fix this. Different pipes need different specs, The E2 quiet pipe does not work well with the "uncorked" jetting. Somewhere between stock and uncorked will be your answer. I am giving up this pipe for stock.
Chris
  • 4 replies
  • Hot  29 replies
  • 22 replies
  • Hot  186 replies
