Front axle alignment
4 replies to this topic
  • Dp2boy
Posted October 23, 2006 - 03:43 PM
Is there a correct procedure or order for reinstalling the front axle ? It seems like I read an article a long time ago that stated you should tighten the left cinch bolts first then the axle nut then the right cinch bolts ? But I probably have that all messed up.
Posted October 23, 2006 - 04:03 PM
The manual simply says to first tighten the axle nut, then bounce the front end several times with the brake on, then tighten the axle pinch bolts. What I think is wrong with that is that tightening the axle with the brake side pinch bolts loose will interfere with the brake side axle lug clamping on the axle correctly. On the other hand, it is certainly true that tightening the pinch bolts first will keep the axle from being drawn through and seated against the axle lug as it should.
So, what I do is run the axle nut down to about 20 ft/lb, then tighten the brake side pinch bolts (not the right side) to about 7-9 ft/lb, then tighten the axle nut completely. At that point I finish tightening the brake side pinch bolts, bounce the front end, which lets the axle find where the forks want it to be, then tighten the right side axle lug. Since the brake side lug will be held in place by the nut in any case, there is no reason to leave it loose before centering the axle.
  • Dp2boy
Posted October 23, 2006 - 04:15 PM
Sounds feasible Gray, I think you are basically saying the same thing as the article I mentioned. Thanks,
  • aford541
Posted October 23, 2006 - 07:00 PM
I have a friend that compresses the forks as far as he can before tightening the right side pinch bolt so the alignment is correct because the sliders are as far in the upper tubes as possible.
I have done it that way and can't tell a difference in the performance of the fork.
  • cowboyona426
Posted October 23, 2006 - 07:50 PM
I do something similar to grayracer, but I spin the front wheel with the bike on a stand and hit the front brake several times to let the wheel center itself... has always worked good for me.
  • Hot  38 replies
  • Hot  36 replies
  • On January 15, 2017
  • Hot  30 replies
