Bk Mod Spring Question
1 reply to this topic
  • trail
Posted October 23, 2006 - 01:26 PM
I got it drilled and tapped but I cant find a good spring anywhere....
I found one from an ink pen but it dosent really put and pressure on the screw...
How often will the AP need adjusted after I set it up the first time? Can I just put a little dab of Silicon on the screw so it doset move?:mad:
Also I am at 155 main and 2 slot for the neddle running at 8k-13k feet. 158 main at 5500 feet...
What changes should I make if any after setting the AP?
  • byggd
Posted October 23, 2006 - 02:28 PM
I used a spring from a pen.... I just streached it out a bit befor installing it, plus the throttle cable cover rests on the screw when installed and should help keep it in place. Once adjusted it should need little re-adjustment.
  • Hot  36 replies
  • Hot  113 replies
  • On January 15, 2017
