Need suspension advice for 07(200lb rider)
13 replies to this topic
  • doublecaser
Posted October 23, 2006 - 05:46 AM
Suspension is great but seems a little soft. After landing from a jump I'm ready to go but bike is still boinging around. It's like I have to wait for it to finish. I am playing with the clickers. Anyone have any tips. 200lb MX rider. Thanks
  • Ga426owner
Posted October 23, 2006 - 05:56 AM
Is the suspension broken in yet?
Did you slow the rebound down? Try 2-3 clicks to H on the rear shock - bottom. I assume forks and shock have been set to STD positions??
  • doublecaser
Posted October 23, 2006 - 06:06 AM
Yes broken in, two track rides. Yes standard positions. The rear actually felt like it had too much rebound off showroom floor. I was hoping not to have to revalve.
  • Ga426owner
Posted October 23, 2006 - 06:12 AM
I would say give it at least 5hrs of riding time on them before they are good and broken in.....
try to increase the rebound dampning 2-3 clicks on the shock and maybe 1-2 clicks on the forks - see what results give....
Posted October 23, 2006 - 08:15 AM
Assuming your weight of 200 pounds is your weigh when not in your riding gear, the springs are about one step too light for you on both ends. You should consider going to .48 fork springs, and a 5.6 rear. Until the spring rates are right, it's going to be tough to get the suspension in balance.
  • Ranger18
Posted October 23, 2006 - 12:36 PM
Do what I did. Loose weight, it's easy, and cheep.
(I'm Not trying to be a smart ass, I'm dead ass serious)
  • doublecaser
Posted October 23, 2006 - 12:47 PM
Thanks for the replies, just spoke with my suspension guy who had an 06. He thinks stock fork oil is too low and stock shock valving is too soft. Something about shim stack is only 5 when it should be 10. I'll keep fiddling with it.
  • WFOracer
Posted October 23, 2006 - 01:11 PM
Just curious what level rider are you, and what kind of riding do you do?
I am $2 bills as well and I also have the bottoming problem. Although my bike feels rougher than hell in the breaking bumps. My forks feel too stiff in breaking bumps and too soft on big stuff.
Posted October 23, 2006 - 02:02 PM
J Although my bike feels rougher than hell in the breaking bumps. My forks feel too stiff in breaking bumps and too soft on big stuff.
Fairly classic symptoms of too-soft springing with too much damping cranked in to make up for it.
But you might try removing 5cc from each outer chamber.
  • WFOracer
Posted October 23, 2006 - 03:31 PM
Good to know...thanks! :mad:
  • mxracer206
Posted October 23, 2006 - 03:42 PM
I felt the rear rebound was to fast also but I think the real culprit ended up being that the front rebound was to slow. The bike seemed to wan't to jump rear end high but was OK going out 3 clicks on front rebound. You will probably need springs for your weight but until then do as grayracer said and add some oil to the forks. Also keep an eye on the rear sag, our spring set a couple of times and you may need to re-do your sag accordingly. You should be able to get it close enough to ride, I am a 200 pounder and it was not bad when we got all set.
Posted October 23, 2006 - 03:49 PM
... until then do as grayracer said and add some oil to the forks.
¿? What I said was....
  • aford541
Posted October 23, 2006 - 07:03 PM
We just had a 07 done by ENZO for a friend that weighed 215 with gear we used the stock rear spring (they said it rated at 5.7) with .48 fronts but we redid the valving which will make a big difference the rider is a 40+ Pro.
  • mxracer206
Posted October 23, 2006 - 08:36 PM
My bad grayracer, I did not read that correctly.
WFOracer, going out on the rebound may help with the braking bumps and adding 5cc to 10cc fork oil will help the bottoming. Hopefully the added oil will not magnify the harshness, if so you may need heavier fork springs and then you can run less fork oil.
  • Hot  79 replies
  • 0 reviews
Motocross
  • Hot  491 replies
