2001 yz250 2 stroke forks on a 2004 yz450f is a revalve needed
5 replies to this topic
  • dwnlowx
Posted October 21, 2006 - 03:01 PM
my forks are leaking on my 450 and i have some 2001 yz250 2 stroke forks with a fresh revlave im wondering if i can put them on the 450. i know they are the smae forks but are they differnt valving for 2 stroke or what i have know clue any info helps
  • tmauto69
Posted October 21, 2006 - 05:09 PM
No, they changed to a 48mm fork in '04 so they won't fit in your clamps. If you have your clamps off of the 250 they will fit in the 450 steering head on the frame.
  • aford541
Posted October 21, 2006 - 06:49 PM
The triple clamp should be the same but the 2 stroke bike is 20+ pounds lighter than the 4 stroke so a revalve should be in order.
  • mxracer206
Posted October 21, 2006 - 07:19 PM
[quote name='dwnlowx']my forks are leaking on my 450 and i have some 2001 yz250 2 stroke forks with a fresh revlave im wondering if i can put them on the 450. i know they are the smae forks but are they differnt valving for 2 stroke or what i have know clue any info helps[/QUOTE
Not only are the 04 forks larger in diameter but the internals are much better than the older forks. I doubt you would be happy with the switch no matter how well the 01 forks are valved.
  • dwnlowx
Posted October 21, 2006 - 07:55 PM
cool i researched a little teh clampsare different is it possible to put 06 forks on a 04
Posted October 21, 2006 - 09:12 PM
Probably, yes, if you use the '06 clamps. You may find a difference in the stem length, or the bearing diameters.
  • Hot  36 replies
  • 10 replies
  • Hot  50 replies
