carburetor problems
3 replies to this topic
  • izzywr
Posted October 21, 2006 - 09:06 AM
Hi all,
i have replaced a broken valve, needle. since then sometimes the engine is "stuck" in high rpm.
could the reason be that i installed the seal the wrong way?:thumbsdn:
any other suggestions?
thanks. :devil:
  • bandit99
Posted October 21, 2006 - 10:20 AM
It sounds like a sticky throttle. Check the linkage and your cables. Maybe it is getting hung up on something. I would check the choke linkage too.
  • izzywr
Posted October 22, 2006 - 06:14 AM
Thanks for the reply.
checked again. dont think that's the issue. the throttle cable is new and the linkage seems fine.
what do u think of the seal issue? does it have a direction?
:mad:
  • GCannon
Posted October 23, 2006 - 08:56 AM
What Year is your Bike? did you check the Throttle slde for hair line cracks.
You should search for this there are lots of info including pictures on this issue.
