Yz 426 starts then dies
7 replies to this topic
  • snakeoil
Posted October 20, 2006 - 07:55 AM
My YZ has been parked for a couple months and now starts and then dies after a few seconds. Anyone have an idea what might be the problem.
  • GCannon
Posted October 20, 2006 - 08:07 AM
Clean the Carburetor! Clean the air filter while your at it.
This will be a good start. BTW that small allen head screw on the bottom side left of the carb bowl is a float bowl drain. Use it every time you put your bike away and you have less of this trouble.
  • snakeoil
Posted October 20, 2006 - 08:19 AM
Thanks,
Just cleaned it still the same.
  • ISBB
Posted October 20, 2006 - 10:50 AM
pull the pilot i bet its plugged.. :devil:
  • SUnruh
Posted October 20, 2006 - 10:54 AM
or the pilot air jet is plugged
  • jbrooks26
Posted October 20, 2006 - 12:45 PM
Could also be a clogged vent tube on the fuel tank. How long will it run after you start it? If the vent on the tank, or the vents on the carb get plugged it will not allow fuel through the carb. The gas tank vent will not allow the carb bowl to fill, the carb vents clogging will keep the bowl from letting any fuel out and into the engine. Just a few other things to check. Hope this helps.
Josh
Posted October 20, 2006 - 01:00 PM
If the vent on the tank, or the vents on the carb get plugged ...
or the check valve in the vent line is upside down (arrow should point to the tank)
  • jbrooks26
Posted October 20, 2006 - 02:30 PM
That is a good point, thanks Gray.
Josh
  • Hot  50 replies
  • 10 replies
  • 0 replies
  • Hot  113 replies
