Replacing clutch arm seal XR600R
1 reply to this topic
  • Terez
Posted October 18, 2006 - 12:47 AM
Need to replace the clutch arm seal on my 90 XR600R
I guess I will replace the seal and bearing while it's out?
Can I just pull the arm out of the case or do I have to remove the side case?
Any helpful advice/tips as I haven't done this before.
Thanks
PS Is the extended clutch arm worthwhile in reducing clutch pull?
Seems a good time to do it if I am.
  • simon@vic
Posted October 18, 2006 - 06:53 AM
to change the seal on MOST bikes {dont know about the 600} all you need to do is:
-detach the cable
-spin the whole arm and shaft 1/2 a turn
-pull it up and out
-pop out the seal
if you want to do the bearing you will have to remove the cover.
