Is the stock WR426 taillight have a brake light?
2 replies to this topic
  • NuckingFuts
Posted October 17, 2006 - 08:18 PM
My 02' WR426 has 3 leads (one of which is not in use) from the tail light and the bulb has dual filaments so Im assuming the unused lead is for attachment to a rear brake pressure switch.
Can anyone confirm this?
  • billygoat
Posted October 17, 2006 - 08:23 PM
You are correct. Just make pigtail power wire and add a brake switch (mechanical or pressure) and complete the circuit. I think I had to change the bulb as well to a two filament type, but check yours.
  • bigdrtrdr
Posted October 18, 2006 - 09:42 AM
Ya its got the proper wiring, make sure to use a heavy duty lamp or an LED or you will be replacing the bulb often.
