Wheels and Tank question
2 replies to this topic
  • mexihonkey
Posted October 17, 2006 - 02:46 PM
I just got a '01 650r and was wondering:
1) I have a spare wheel set for my 04 CRF450r (I run an 18" rear) - Obviously the front won't fit but will the rear fit my 650?
2) I need to order a tank and don't really know the fuel range of this beast. Is the 4 gallon overkill for dez racing (only using this in the bitd series) or is the 3.2 good enough? I have never had a problem with the 3.2 on my 450, I can get just over 80 miles at race pace and just over 100 puttn' around.
Thanks in advance.
  • Koko Azuela
Posted October 17, 2006 - 05:06 PM
Thanks in advance.
1) No, it won't fit
2) The 3.4 gal will give you around 70-80 miles at the most on race pace, the 4gal will give you around 100-105 mile at race pace, if only racing BITD go with the smaller tank, if you plan on baja, get the big one, gas is precious in baja :devil: :thumbsdn:
  • Mojave Monster
Posted October 17, 2006 - 08:30 PM
I called IMS with the same type of question. The IMS 3.2 is very, very close to stock size. The 4.6 is plus 1.4 gallons. I get about 65 miles on the stock and 100 on the 4.6 All things being relative I would assume you would get better distance the I. Check and see what kind of milage you get, mile per gallon not miles per tank, and do the math.
  • 7 replies
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
  • 0 replies
