Countershaft Nut Stuck
7 replies to this topic
  • Indiana
Posted October 17, 2006 - 01:10 PM
I have an 03 YZ450 and want to put a new front sprocket on. Problem is I cannot get the damn nut off. I assume (probably my first mistake) that it is not reverse threaded. I also assume that it is probably a bad place to apply heat. I've tried all I know to do. You guys have any ideas?
Posted October 17, 2006 - 01:21 PM
The nut is a normal, right hand thread. If you don't have access to an impact wrench, try putting the bike in a higher gear with the chain still on, and place a piece of wood or a hammer handle across the swing arm through the wheel spokes, as close to the rim as possible. Then crank away with a good fitting socket on a long breaker bar.
  • xcape
Posted October 17, 2006 - 01:39 PM
I put my foot on the rear brake as well
  • Wyatt
Posted October 17, 2006 - 02:24 PM
Use the above mentioned methods to retorque, but get your hands on an impact to take that thing off.
  • 642MX
Posted October 17, 2006 - 05:43 PM
You can use a small amout of heat too. Just don't get carried away, you don't want to melt the countershaft seal.
  • 00YZ426FMRCD
Posted October 17, 2006 - 05:54 PM
Damn you are much more flexible than I am! :devil: Good idea - I have done that as well. I usually have my son or wife stand on the brakes and jam a wrench wrapped with a rag between the chain and sprocket. I would be very leary about torquing it in gear. Just me.
  • Indiana
Posted October 18, 2006 - 12:33 PM
Thanks guys, I had my son standing on the brake and had it in gear, with a breaker bar on the socket wrench and it still would eventually push the sprocket forward. I'll give a go with some of your suggestions.
  • andy250
Posted October 18, 2006 - 01:13 PM
You did push the lock washer down didn't you?
  • Hot  47 replies
  • Hot  79 replies
  • Hot  28 replies
