A little bit of 01 426 help
6 replies to this topic
  • Urps
Posted October 14, 2006 - 02:49 PM
Ive got one of my friends 01 yzf426's and it doesnt want to idle at all, it runs just fine but i cant get it to idle for the life of me, would that be the fuel air screw or the actual idle adjustment?
if you think its the idle adjustment how do i even change that?
and how can i tell if the fuel air screw is set right for the weather?
do i set it the same way i would a pilot air screw on a 2 stroke, by dialing in the fastest idle?
any help is appreciated
  • GONE1445
Posted October 14, 2006 - 04:03 PM
did it work fine for your friend before?? or has it always ran like this
your friend might have adjusted to idle down too low you can adjust it with the big black knob on the left side of the carb it hangs next to the bowl
tighten it to raise the idle
mine did the same thing but out of no where and I took the jets out of the carb and found a piece of rubber in there and took it out and runs fine
and I don't know about the fuel screw
  • stillsun
Posted October 14, 2006 - 07:16 PM
...and if he's messed with the jetting the pilot may be way too rich (if it wants to lay down) or too lean (if it wants to idle high), or idle screw for that matter.
J
  • Urps
Posted October 15, 2006 - 12:27 AM
as long as he has had it its not really wanted to idle....
but thanks for the input
  • RD73
Posted October 15, 2006 - 05:59 AM
Choke it first. Let it get warm, then it will idle.
  • Urps
Posted October 15, 2006 - 11:28 AM
Thats what im getting at even when it is warm it doesnt really want to idle...
The only time it will idle is when the choke is pulled....i let the idle die out a little with the choke pulled and then it runs for maybe a max of five seconds and then just quits....
  • GONE1445
Posted October 15, 2006 - 11:38 AM
it sounds like what mine did but mine idled fine then started acting up but if he bought it used it might still be the same problem take the carb off and, clean, clean, clean and don't forget to take the jets out and clean behind them that is where I found a piece of debris that caused my problem
other than that adjust the idle screw and see if its that
  • Hot  113 replies
  • 10 replies
  • Hot  30 replies
