XR650L Choke Question
6 replies to this topic
  • obiwanblee
Posted October 14, 2006 - 02:45 PM
I just got my hands on a '94 XR650L but I seem to be having problems with the choke. When I pull it towards me (I think this is turning the choke on?) with the cable showing, it idles much lower than when the lever is closed (choke off?). In fact, with the lever closed all the way towards the bike, it sounds like it's fast idling or even revving slightly. Maybe I have this backwards? The bike also surges when on the throttle and I'm not sure where to start looking for that problem.
Sorry if these are really stupid questions, but the last time I was on a carbed bike was in MSF and they are a complete mystery to me.
  • rebelventurer
Posted October 14, 2006 - 04:12 PM
yep, pull the lever towards the handlebars and you are choking it push away and your not! Surging sounds like carb issues, probably some shilack(spelling) dried up gas deposits in the carb partially blocking passages in the carb! Check the air filter first make sure its relatively clean. Oh, welcome to TT, lots of people here that know their stuff so if you wonder about something, just ask. Has it been parked for a while?
  • obiwanblee
Posted October 14, 2006 - 06:01 PM
Hmm, that's weird then. Why would it idle higher when the choke is off? I have no idea how long the bike was sitting, what I do know is that it was unable to start for a while because of a dead CDI, which I replaced.
The choke thing concerns me quite a bit, since the bike seems to be functioning opposite of what the choke lever is doing, unless it's normal for the XRs to idle higher with the choke off.
  • obiwanblee
Posted October 15, 2006 - 05:07 PM
Bump!
  • brichter
Posted October 16, 2006 - 02:55 PM
Sounds like you got some crap in the carb, probably time to clean them or it's just set way too ricvh at idle. What color is the plug?
You pick it up off CL?
  • rebelventurer
Posted October 16, 2006 - 02:58 PM
Bump, what!
when mines warm, wont idle at all with choke!
  • cleonard
Posted October 16, 2006 - 03:52 PM
I can think of two possible issues. Crap in the carb like others have suggested, or an air leak. With the bike warm and idling spray some carb cleaner on the ends of boot between the carb and the engine. They usually leak where the boot attaches to the engine. When the carb cleaner hit a leak it will cause the engine speed to change as the carb cleaner gets sucked in.
If the bike was sitting and there was gas in the carb, it needs some cleaning for sure.
  • 4 replies
  • Hot  60 replies
  • Hot  29 replies
Washington
  • Hot  32 replies
  • Hot  35 replies
