best sproket combo for woods riding
11 replies to this topic
  • sky-bot
Posted October 13, 2006 - 12:29 PM
Looking for suggestions on what ratio to run on my 2001 426 for tight woods trails? During last weekends ride coming out of some moderate turns in third gear it felt like the motor was not turning enough R's to be crisp. I was thinking of going to a 52 tooth rear vs. the stock 49 tooth? It wasn't that far off, but any suggestion would be appreciated.
  • Zique
Posted October 13, 2006 - 03:39 PM
It ultimately depends on what your riding style is and where you like to be in the powerband, but I ran 14/51 and it did great. I just replaced my stator and f/w with one from a WR (I tell you this because it is about 8 oz. heavier) and went back to stock gearing to see if the added weight will be of benefit.
  • 642MX
Posted October 13, 2006 - 06:39 PM
I use stock gearing.
  • cowboyona426
Posted October 13, 2006 - 08:14 PM
13/52 worked good for me in the really ugly stuff, but you could probably get away with 14/52 most of the time.
  • fritzelman
Posted October 13, 2006 - 09:54 PM
13/50 here. Not quite low enough for the tight trails I ride, debating on going to a 13/52 or 13/53, but haven't talked myself into paying for another sprocket that wont give me much lower gearing. Tryin to get some lights on it first.
  • 00YZ426FMRCD
Posted October 13, 2006 - 10:11 PM
Ran a 14/52 for a while. Great for the tight stuff/woods - really low. I really like a 14/50. Good combo for woods and MX. I believe the stock is 14/49.
  • Goosedog
Posted October 14, 2006 - 05:47 AM
13/51 plus a 12oz flywheel weight and the 426 becomes the ultimate woods monster. :devil:
  • PumpkinHumper
Posted October 14, 2006 - 06:55 AM
Here in Michigan in the tight trees droping 1 tooth on the front sprocket is a real common mod. Works great.
  • NOMADAK
Posted October 14, 2006 - 09:22 AM
Agree with a 13 countershaft, then play with the rear 50-53 tooth should work well for the tight stuff.
  • donutman126
Posted October 14, 2006 - 05:57 PM
I got a 13/51 on my bike and I like it a lot. Now instead of doing hills in 2nd gear I can easily pull 3rd or 4th
  • Matt96xr6
Posted October 14, 2006 - 06:21 PM
works great for about everything! MX, AX and woods.
  • stillsun
Posted October 14, 2006 - 07:20 PM
I run stock 14/49 with 14 oz flywheel and a 444 big bore kit, seems to work great for tight single track or wide open beach runs on the rivers.
J
Motocross
  • Hot  491 replies
  • Hot  113 replies
  • Hot  47 replies
  • 0 replies
