Pro Taper Bars?
11 replies to this topic
  • Beejay
Posted October 12, 2006 - 06:58 PM
So I fitted a pair of Pro Taper bars a few weeks back & seem to be getting much more vibration through my hands now. Thinking about filling the ends with silicone with sand in the middle. Anyone tried this or experienced the same after fitting these bars?
  • Bullwinkle
Posted October 12, 2006 - 11:46 PM
I have a little too much vibration as well. I've been thinking about trying Bar Snake.
  • Beejay
Posted October 13, 2006 - 05:23 PM
Bullwinkle, you got Pro Tapers' on or the standard Renthal?
  • Alley Cat
Posted October 13, 2006 - 05:44 PM
Don't worry about the sand Beejay, just use silicone. It suprisingly makes a big difference.
  • boer
Posted October 13, 2006 - 07:11 PM
Honestly, when I changed to Pro Tapers I couldn't feel a difference. I was too happy being able to stand straight without having to crouch forward. The silicone in the ends does make sense though, and it's not permanent so give it a try and let us know if it worked :devil:
  • Seabass
Posted October 13, 2006 - 07:25 PM
I'd say try a steering damper but squirting silicone in the ends of your bars is way cheaper.
  • Bullwinkle
Posted October 14, 2006 - 06:17 AM
Renthal.
:devil:
  • Beejay
Posted October 14, 2006 - 11:29 AM
Thats what convinced me to change, the standing. I'm going to give it a try in a week or two, we're in shut down mode here & I'm working 12hr shifts 7 days a week. Give you some feedback soon.
I'm also going to trim about 20mm from each end.
  • 89TRX350RX
Posted October 17, 2006 - 03:44 PM
Careful if you run bark busters on the tapers and you cut the bars... the mounts are designed to fit in one spot on the bars and if you narrow them, the mounts move towards the center and ther bars are bigger... may have to mod them to make 'em fit?!?!?
  • Beejay
Posted October 17, 2006 - 10:28 PM
:devil: got that under contol, some hand filing & longer machine screws.
  • simon@vic
Posted October 18, 2006 - 06:59 AM
mine work fin with cut bars.......... 1.5cm from each side.......
  • kembro
Posted October 19, 2006 - 12:41 PM
Same vibe problem here, how did the silicon work out?
Cheers
Kem
