it has to be possible.....
7 replies to this topic
  • DevilishYZ450F
Posted October 12, 2006 - 01:07 PM
hasnt some one rewound a YZ450 stator for lights yet? i know it can be done on my xr100 so why not the YZ???
Posted October 12, 2006 - 01:09 PM
It's possible, but they still only put out 50 watts. It's just a tiny little stator, that's all.
  • 02YZ426
Posted October 12, 2006 - 01:56 PM
There are 4 ignition posts on your stock stator, very tiny like gray said. Problem is, if you want to wind it for lights, you have to give up 2 posts for ignition and use the remaining for lights. The Electrex USA ESL380 stator is designed like this.... but lots of people had the ignition side burn out... 2 posts is not enough, you need all 4 for ignition. Thats why you either go with an external stator like the Eline or a WR flywheel and stator.
  • DevilishYZ450F
Posted October 12, 2006 - 02:26 PM
will the 03 wr flywheel and stator drop in my 03 yz?
  • 02YZ426
Posted October 12, 2006 - 02:36 PM
This is what you need http://www.electrosp...SK_94246DK.html
Scroll down to WR flywheel +stator. $317
Posted October 12, 2006 - 04:15 PM
No. From the web page: NOTE: Up to 02 models only
The only flywheel and stator that can be installed on any YZ450, including the '06/'07, is a YZ450 unit. The crankshaft and crankcases on the WR450 are different than the YZ, and different from previous WR's, in that the left axle was lengthened and the flywheel turned "inside out" to accommodate the electric starter drive unit. They will not interchange short of buying some $1900 worth of WR parts. Sorry, we're stuck with what we bought.
  • 02YZ426
Posted October 12, 2006 - 05:23 PM
I didn't even notice that doesn't work on the 450...ooops! That really blows, so there is no way on a 450 to get more than 50watts? I wonder if E-line makes a kit for the 450. Well, you can always get the L51 stator and Trail Tech flywheel.http://www.electrosp...sk_94261DK.html
Posted October 12, 2006 - 06:45 PM
E-Line does make an external stator kit. It's neither pretty nor cheap, and as I recall, it has no oil filler plug, either.
  • 0 replies
  • Hot  47 replies
  • Hot  113 replies
  • Hot  38 replies
