Fixing a melted hose
5 replies to this topic
  • B-Rock
Posted October 12, 2006 - 11:50 AM
I have no idea how this happened, but I melted my coolant reservoir tank breather hose. (the clear one furthest from the camera in this picture.... doesnt show the melt in the pic)
http://i105.photobuc...een/reroute.jpg
I started my bike after deing away for a week, and I guess I somehow pushed the hose against the header. Anyways, I noticed some coolant leak onto the ground, and then I could smell something burning. The hose is pretty much melted right through. :devil:
Anyone have suggestions on how to fix this. I was going to just cut out the melted section and use a plumbing connector to atach them together? That hose is 1/4" right?
Would anyone do something different?
  • mangler
Posted October 12, 2006 - 12:02 PM
I did the exact same thing. melted it.
So instead of replacing the entire thing I got a joiner? and new clear tube and spliced in a new section. seems to work good.
I cut off the hose from below the melted section and brought it into Ace hardware for fit.
Good luck.
  • B-Rock
Posted October 12, 2006 - 12:09 PM
Good luck.
Is that hose 1/4"? Was the joiner you got 3/16" ?
I'm going to the hardware store today if I can figure it out. It's just a pain with my ride out of comission, so I dont want to make a million trips
  • Indy_WR450
Posted October 12, 2006 - 12:17 PM
I just cut mine to stop at the top of the shock!
I recommend you route one carb vent line from each side of your carb to the air box. I have seen many of my riding buddies ice up or fail deep river crossings because of it. The factory routing is a joke!
  • B-Rock
Posted October 12, 2006 - 12:27 PM
wow thats short indy!
I have read of many people rerouting like you said. It is definitely on my to do list.
Thanks for both your help.
  • mangler
Posted October 12, 2006 - 12:36 PM
Once I found a match at ACE for the inner diameter of the hose I cut off a 3 foot section off the roll and brought it over to the plumbing section and found the hose connector fitting that fit perfect and snug.
Good Luck
