have to remove head pipe to change oil filter?
3 replies to this topic
  • buzzgrizz
Posted October 11, 2006 - 07:05 PM
My son has a 2000 YZF 426 and every time I change the oil filter I have to remove the head pipe to do it. I think they corrected the problem in 01 but wondering if there any after market head pipes I can install to fix this problem or if a 01 or 02 pipe would work ?
  • Wyatt
Posted October 11, 2006 - 07:14 PM
I think an '01 or '02 headpipe will swap in just fine. I amy be wrong, but I almost sure that it will.
Posted October 11, 2006 - 07:58 PM
I believe you're right. Most any aftermarket pipe should address that, too.
  • gbalias
Posted October 11, 2006 - 08:21 PM
i know that the power bomb FMF will fix the problem. i do the maintenance for my 400 and my friends 426 and i loosen the bolts enough to slightly rotate the header up a bit. you can remove the filter by doing that just fine and you dont have to completely remove the header. dunno if that helps at all. but i do agree....what were they thinking when they designed that?
  • Hot  50 replies
  • Hot  28 replies
  • Hot  36 replies
  • Hot  30 replies
