ok i hear alot about it now how do I do it?
9 replies to this topic
  • matts06yzf
Posted October 11, 2006 - 04:25 PM
Before I get bashed search feature is down for past 2 nights. on my 06yz450f I hear everybody saying move forks down to 1st line yada yada. What 1st line and is this easy or a pain? anyone have a good article on how to to this? any help appreciated thanks
  • DPW
Posted October 11, 2006 - 04:30 PM
Very easy...you will be moving the forks up in the clamps not down. Loosen the four pinch bolts on each of the triple clamps..upper and lower and slide the forks up to the first line. Re-torque the bolts and enjoy...
  • matts06yzf
Posted October 11, 2006 - 05:40 PM
what 1st line ? what line am I looking for?
  • almostinvincible119
Posted October 11, 2006 - 06:04 PM
the small indentions at the top of the fork tube, that are about 10mm (?) below the fork cap. MAKE SURE that both sides are EQUAL or your bike will handle like a flaming sack of poo on blocks! Just loosen the pinch bolts and slide the tubes upwards, very easy. While your at it, check your axle nut cause they work loose really easy. Dont over tighten it, its aluminum.
  • barch88
Posted October 11, 2006 - 06:12 PM
Once you loosen the fork and pull it up you will see the line.
  • Ga426owner
Posted October 12, 2006 - 05:22 AM
Loosen top and bottom pinch bolts and raise the forks. Use a torgue wrench to tighten top at 14ftlbs and bottom at 17ftlbs or per torgue range in the manual
  • DPW
Posted October 12, 2006 - 08:30 AM
flip-flop the torque setting 17 top and bottom 14..
  • Ga426owner
Posted October 12, 2006 - 09:34 AM
Thanks DPW - too much coffee this am..........
Posted October 12, 2006 - 12:53 PM
And on that note, here's a picture of "the line" for you.
  • av
Posted October 12, 2006 - 01:46 PM
Don't forget to re-seat/realign you forks once you have changed their positions on the triple clamps - i.e. once the triple clamps are tightened, loosen the axle & pinch bolts and bounce up & down on the forks to re-seat them so that they won't bind, then tighten the axle & pinch bolts back up to spec. You really should tighten the top triple clamps by itself, keep the lower clamp a little loose, re-seat the forks, then tighten the lower clamps, axle bolts & pinch bolts at the bottom.
  • 0 replies
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • 5 replies
