Vapor computer
9 replies to this topic
  • pbusanga
Posted October 09, 2006 - 06:20 AM
Hi does anyone know which Protector / mount is used to fit the vapor to the XR650R.
Trailtech mention the use of protector mount # 022-PO5 but i cant find that on their website. :devil:
any feed back on the Vapor?
  • Maroast
Posted October 09, 2006 - 12:19 PM
I have the vapor on my 06 xr650r and like it...as for the protector i use the 022-TM model with the stock top triple clamp...
However, I put bar risers on so I could run 1 1/8 bars and that protector doesn’t work with that setup...So I fabricated an adaptor (just a small piece of alum with holes in it) so I could mount the protector/computer to the two small threaded holes on the top triple clamp (I think one of the holes is where stock trip meter was mounted). The bolts that thread thought the adaptor and into the top clamp have nuts/washers on the underside for extra strength.
This is a solid setup and has survived months of riding and a pretty hard off-road wreck…its never given ANY problems… hope this helps. :devil:
-T
  • pbusanga
Posted October 09, 2006 - 01:19 PM
thanks for info. did you have any trouble connecting the temp sensor to the engine. did you have to buy any extra parts. reason i am being so particular is that i am having the Vapor sent to me in Africa and it is not easy to get bits and pieces to make things fit
thanks in advance
  • Maroast
Posted October 09, 2006 - 02:44 PM
No problems whats-so-ever with the temp...just splice the sensor into the cooling line where it exits the engine...dont forget the read the infor book that comes with the comp...you have to do a special reset ionce the temp sensor is hooked up. I forgot to do this reset and the temp never came up...I thought the unit was broke.
I didnt need anything extra. Drilling the hole in the rotor was kinda hard though.
Anything else just ask away
  • pburke
Posted October 09, 2006 - 03:28 PM
the hose clamps that come with the kit don't fit (too small) and the sensor unit is a little too small for the tubing on the XRR, so you have to build it up with some Teflon tape or something similar.
Once you work around these small issues it works great - shows me that I need a fan and that my thermostat is probably stuck open
Peter
  • Rick_Laut
Posted October 09, 2006 - 05:33 PM
I just got a Vapor last week and had no difficulty with it. I got it with the 022-P04 mount. I have Pro-Taper bars with the risers for the stock triple clamp. The mount works, but I have to orient the one of the risers backwards to make the width between the allen bolts match the width of the mount.
As for the water temperature sensor.... the clamps were a little small, but they still worked. I didn't build up the diameter of the temperature sensor and haven't had any problems with leaks.
I love the computer.... tested it on a 140 mile ride this past weekend!
Rick
  • frankstr
Posted October 09, 2006 - 05:52 PM
Lets see some pics of the Vapor mounted up....... :devil:
  • XRMANU
Posted October 12, 2006 - 03:06 AM
I have installed my Vapor on my 650R.
Some questions: -pulse per revolution: 0.5 ,1 or 2 on the 650? Default on 4st is 1 ,on 2st also 1?? :devil:
- does change the PPR over certain RPM's (step 2 PPR Vapor manual).
- yellow shift rpm's led : is 6500 a 7000 rpm good for SM/street use?
- red led (over shift) : 8000 rpm?
- high temp warning point: is the default 90°C (190° F)ok ?
- over temp danger point: is the default 110°C (230°F)ok ?
Thanks. :thumbsdn:
  • pburke
Posted October 12, 2006 - 07:17 AM
Thanks. :thumbsdn:
leave the pulse stuff on default - worked for me.
shift light - I have the yellow at 6000 and see it quite frequently. I think the red is at 7500 just to keep me sane. Really up to you. You can change this stuff quite easily to match your riding.
temps - depends again on your riding. 190 degrees for yellow will come on quite easily, at least it does for me. I have the red at 220 just to warn me early enough. So far I have not seen that light come on.
I was thinking of doubling the rpm numbers with the pulse setting so the bar graph on the vapor would get used more effectively, however, I look at the digital rpm readout more than the bar anyway, so I just left it alone.
Have to edit my front tire diameter again - GPS tells me my VAPOR underindicates by about 3mph at 55.
  • azfabguy
Posted October 12, 2006 - 09:38 PM
i made my vapor mount out of some stainless that i bent up
Honda XR650L 2016
  • 0 reviews
Which thumper motor for a street tracker? by woz
  • Hot  29 replies
  • 22 replies
  • Hot  35 replies
  • 7 replies
