Quick Carb question
3 replies to this topic
  • warchief_ryan
Posted October 08, 2006 - 11:36 AM
Sure you XRL guys are familiar with the Daves Mods, Wanted to know that’s for everything stock carb wise right?
  • rebelventurer
Posted October 08, 2006 - 11:46 AM
I believe the idea is to improve throttle response and fuel mixture under all conditions, to change the fuel mixture you must change the 152 stock jet for a larger one in the 158-165 range depending on your other mods and elevation above sea level. However I am sure if you performed the mods and retained the stock jetting I would say that it would have to improve drivability, and shimming the needle minutely richens the bike. If you did the mods on a stock bike without changing the main jet, I would NOT remove the snorkel or add aftermarket exhuast.
  • warchief_ryan
Posted October 09, 2006 - 07:48 PM
What I was thinking about doing was the carb mods, desmogg, remove snorkel and maybe take off the exhaust baffle/end cap. How do you think it might work out?
  • rebelventurer
Posted October 09, 2006 - 08:50 PM
change your main jet to a 160 and you should be fine, put in a new spark plug run it for a while pull the plug and check it out, tthe magic color is brown, not grey, nor black. good luck with it :devil:
  • Hot  29 replies
  • 3 replies
  • 9 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 4 replies
