Need some torque specs QUICK
2 replies to this topic
  • DefaultPeanut
Posted October 06, 2006 - 08:56 PM
Hello there. I am working on a friend's (Andrew) 2003 YZ450F. He needed his valves checked and shimmed. He does not have a manual for this bike so he sas been doing the *it feels tight enough* to the oil filter and drain plugs. I have a YZ250F so I know the general specs but I want to be 100% sure.
I need to know the torque specs for the:
- top engine mount bolts ( all 3 )
- cam caps
- drain plugs
- cam chain tensioner (mounts and top bolt)
I was thingking of using the specs from my 250F but I thought the cam caps atleast would be different.
Any help would be greatly appreciated.
  • Diode663
Posted October 06, 2006 - 09:12 PM
Cam chain tensioner bolts are 8NMs I belive. The cam caps are 75 in/lbs. I just give the upper engine mount bolts a good torquing and the drain bolts I do by feel so I cant help you there.
  • DefaultPeanut
Posted October 06, 2006 - 10:43 PM
Alright... I'm not doubting you but the cap bolts on my 250F are 86 in/lbs...
