Tool box suggestion
Tools
No replies to this topic
  • STILL_KICKIN
Posted 05 October 2006 - 06:16 PM
My toolbox list for everyday maintenance and teardowns.
Only some uses mentioned, and tools that I think most new do it yourselfers overlook.
I think everyone that wants to work on there own bikes should have knowledge of the tools that can benefit them in maintaining there bike.
Vernier Calipers - Uses: Brake rotors wear, rough measurement of Piston O.D. while I'm checking rings, Fork height above clamps, so they are both equal, etc.
Feeler gauges - Uses: Piston to bore clearance, ring to ring groove clearance, valves, etc.
Dial indicator with magnetic base and extensions - Uses: Ensure you are on TDC of stroke for static timing, check run out on rims, check if flywheel is running true, etc.
Bore Mics, inside mics, outside mics - Uses: To be able to tell if it's time for a piston replacement.
Flywheel puller - Self-explanatory
Multimeter - Uses: check for grounds, continuity of coils, etc.
Snap ring pliers - Self-Explanatory
Aviation Wire Pliers, and wire - Uses: Keep things from falling off. Aid in clamping fuel lines, Handle grips, etc.
This post has been promoted to a wiki
