Question on 15:45 gearing for XR600
4 replies to this topic
  • michaelschorpp
Posted October 04, 2006 - 10:25 AM
I recently changed my XR600 sprockets to 15:45 from 15:48 (stock is 14:48). I use my bike for dual-sporting and the bike is much nicer to ride on the street now. I would like to keep the 45 tooth rear and switch to a 13 or 14 tooth frontsprocket when I do serious off-road stuff. What is the recommended chain length (108 or 110 links)for this setup?
Someone here on TT originally suggested this idea to me years ago.
Mike.
  • SniperTeamBravo
Posted October 04, 2006 - 02:09 PM
Ok, I did 14 (stock) front, and 42 rear because I ride mine (supermotoed) on the street 99% of the ride time. I may do the same thing as you, go to a 13 counter if I want to do some quicker accel or dirt riding but I think I wouldn't do anything to the chain because I could still adjust it with the 13 and the adjusters....what r u trying to do? taking one tooth off the front or adding 1 tooth is like a change of 3 in the rear, so by going from 14~48 to 15~45 your final drive didn't change from stock. Now, if you go to 14~45, it would be like stock less three teeth in the rear....higher than stock therefore quicker but less topend. I did 15~42 and went from 90 on top end to 102 or so top end.
  • michaelschorpp
Posted October 10, 2006 - 06:51 AM
Actually 15:45 and 14:42 are both exactly the same, a 1:3 ratio. How many links are in your chain?
Mike.
  • suharianu
Posted October 10, 2006 - 07:55 AM
I have 15/45 and switch on dirt 14/45- 110 links
  • SniperTeamBravo
Posted October 10, 2006 - 09:22 AM
I think I cut about 4 links out of the stock leinght chain so it would be 106
  • 3 replies
  • 9 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
