oil checks wr450 06
10 replies to this topic
  • dobbo
Posted October 03, 2006 - 12:38 AM
Hey i just bought a wr 450f and when checking the oil it gives me a low reading I just picked it up from the shop.
Is there a special trick to checking the cause i am new to owning a bike.
  • pHreaC
Posted October 03, 2006 - 01:01 AM
Read your manual: there you will read, first turn on your bike; let it run for a while, then check your oil... (if you did not turn it on first you will get a low reading)
regards,
pHreaC
  • dobbo
Posted October 03, 2006 - 02:00 AM
:thumbsup: cheers, thats how it did it, the bike shop must of not put enough in...
  • the bandit
Posted October 03, 2006 - 03:19 AM
i tried to check my oil for the first time the other day and when i unscrewed the dipstick oil started running out. does this mena there's too much oil in?
should i let some out incase it blows a seal or something?
  • boer
Posted October 03, 2006 - 04:47 AM
Yup, there's too much oil. You should drain some oil out.
  • drtbk4ever
Posted October 03, 2006 - 07:14 AM
And make sure you turn the bike off before checking your oil.
  • face_plant
Posted October 03, 2006 - 07:55 AM
i can say if u changed the oil yourself the first time you prpbably forgot to drain the oil tank. i made the same mistake until i read the manual..
  • the bandit
Posted October 04, 2006 - 01:30 AM
i just bought the bike and the person i bought it from had just changed the oil. he must have put way to much in.
what's the quickest way to get it down to the proper level? could i just undo any of the drainage bolts and let a little out at a time?
  • boer
Posted October 04, 2006 - 01:43 AM
I would be on the safe side and drain all the oil and replace with new oil and oil filter as you never know what oil is in there right now. :devil:
  • the bandit
Posted October 04, 2006 - 01:48 AM
i know for a fact it's got new oil and filter in as he was busy doing it the first time i went to see the bike. just a shame he couldn't be bothered to finish the job!
  • texas_hippie
Posted October 06, 2006 - 02:11 PM
Uh huh! :devil:
