Ciao from Italy
291 replies to this topic
  • RC30
Posted December 21, 2006 - 02:46 PM
#81
All the rego gear came off ,sprockets,subframe extension,muffler,overflow bottle,side stand,heat guard on the header,used lighter bolts and nuts,stuff like that.........
Ok weskc35k, your work is like mine.
.........RC30 whar was your nett loss with the new front end?...............
Sorry, what do you mean? Weight........money?
(I have still difficult with English language).
By the way, now in Italy are 11:46 pm, then in Australia?
  • weskc35k
Posted December 21, 2006 - 02:54 PM
#82
All up how much lighter is the complete new front end,what is the weight difference between the old front end and the new ?
  • RC30
Posted December 21, 2006 - 03:11 PM
#83
Ok, now I have completely understand.
From the new front end I have lost about 4kg (8.8lbs).
Ciao Piero
  • RC30
Posted December 22, 2006 - 10:15 AM
#84
The battle of the weight.......#27
Posted Image Stock 0.268 lbs
Posted Image Special 0.189 lbs
Rear brake fluid pipe, metallic braid.
Weight -0.079 lbs :thumbsup:
Total dry weight (verified) stock 308.37 lbs
After step #27........................300.101 lbs .............-8.269 lbs
  • rdahl
Posted December 22, 2006 - 10:51 AM
#85
When you are finished it would be great if you could give a cost/lbs saved. :thumbsup: This is a great thread!
  • RC30
Posted December 23, 2006 - 10:13 AM
#86
The battle of the weight.......#28
Posted Image Stock 0.5 lbs
Posted Image Special 0.381 lbs
Rear brake bracket, stock cutted.
Weight -0.119 lbs :thumbsup: [COLOR="Red"]PROVISIONAL?[/COLOR]
After step #28........................299.982 lbs .............-8.388 lbs
  • RC30
Posted December 24, 2006 - 08:22 AM
#87
The battle of the weight.......#29
Posted Image Stock 0.07 lbs
Rear brake cover, removed.
Weight -0.07 lbs :thumbsup:
After step #29........................299.912 lbs .............-8.458 lbs
  • RC30
Posted December 25, 2006 - 07:45 AM
#88
The battle of the weight.......#30
Posted Image Stock 0.193 lbs
Rear rotor cover, removed.
Weight -0.193 lbs :thumbsup:
After step #30........................299.719 lbs .............-8.651 lbs
  • RC30
Posted December 26, 2006 - 07:49 AM
#89
The battle of the weight.......#31
Posted Image Stock 1.273 lbs
Posted Image Special 1.017 lbs
Rear rotor, Braking Italy.
Weight -0.256 lbs :thumbsup:
After step #31........................299.463 lbs .............-8.907 lbs
  • RC30
Posted December 27, 2006 - 08:54 AM
#90
The battle of the weight.......#32
Posted Image Stock 0.896 lbs
Posted Image Special 0.687 lbs
Front master cylinder, Brembo (radial model) 19mm.
Weight -0.209 lbs :lol:
After step #32........................299.254 lbs .............-9.116 lbs
  • RC30
Posted December 28, 2006 - 10:25 AM
#91
The battle of the weight.......#33
Posted Image Special 0.066 lbs
Front brake fluid tank, Brembo.
Weight +0.066 lbs :lol:
After step #33........................299.32 lbs .............-9.05 lbs
  • rebelventurer
Posted December 28, 2006 - 01:45 PM
#92
RC30, you are doing a wonderful job of listing all your modifications! :lol:
There is more weight to be lost though, Titanium axles, swing arm pivot bolt and fasteners through out the bike can shave off a few more grams.
Lighter seat foam, cover, Titanium sprockets and chain. Also there has to be a lighter rear shock with a titanium shock spring.
  • RC30
Posted December 29, 2006 - 07:39 AM
#93
The battle of the weight.......#34
Posted Image Stock 0.033 lbs
Posted Image Special 0.057 lbs
Switch front brake, hydraulic type.
Weight +0.024 lbs :lol:
After step #34........................299.344 lbs .............-9.026 lbs
  • RC30
Posted December 30, 2006 - 10:49 AM
#94
The battle of the weight.......#35
Posted Image Stock 0.464 lbs
Posted Image Special 0.396 lbs
Front brake fluid pipe, metallic braid.
Weight -0.068 lbs :lol:
After step #35........................299.276 lbs .............-9.094 lbs
  • rebelventurer
Posted December 30, 2006 - 02:29 PM
#95
Keep on dude the little things are adding up I see you getting to 290lbs!:lol:
  • RC30
Posted December 31, 2006 - 05:07 AM
#96
......Also there has to be a lighter rear shock with a titanium shock spring.
Ciao rebelventurer, the titanium shock spring is a good idea but........I have a best idea, which you will see later...........:confused:.........:lol:
......I see you getting to 290lbs!.
Mmmhhhhh.......I hope many lbs lower............:confused:
......There is more weight to be lost though, Titanium axles, swing arm pivot..................Lighter seat foam, cover, Titanium sprockets and chain.......
These are very interesting things, please, do you have links or addresses to direct me?
P.S. Happy New Year!
  • RC30
Posted December 31, 2006 - 10:37 AM
#97
The battle of the weight.......#36
Posted Image Stock 0.072 lbs
Front brake fluid pipe clips, removed.
Weight -0.072 lbs :lol:
After step #36........................299.204 lbs .............-9.166 lbs
  • rebelventurer
Posted December 31, 2006 - 11:29 AM
#98
RC30, here are some links, let us know what you think!
Titanium bolt kits.... www.mettec.com they will custom make bolts, and axles, also.
Super light and strong sprockets and chains.... www.SidewinderSprockets.com
Billet throttle assembly.... www.TERRYCABLE.com
brake stuff..... www.ebcbrakes.com
Idea for rear shock, On one of my sons pit bikes we used a Fox racing air shock, what was remarkable was the fact that it only weighed 1.1 lbs I dont know if they have larger model available, but I know they can be valved for many different setups, and are highly adjustable:thumbsup: check them out at.... http://www.foxracing.../moto_index.htm
Heres a 650 that weighs 275, but given the same attention you are giving yours it would weigh 250lbs or less... http://www.build-stuff.com/CRF650.htm
I hope you can get down below 290 maybe even 275, good luck, once again great job of documentation! :lol: ciao
  • RC30
Posted January 01, 2007 - 07:35 AM
#99
The battle of the weight.......#37
Posted Image Stock 0.354 lbs
Posted Image Special 0.66 lbs
Front brake spacer, MotorQuality Italy based. [COLOR="Red"]PICTURE INCOMPLETE[/COLOR]
Weight +0.306 lbs :lol: [COLOR="Red"]PROVISIONAL[/COLOR]
After step #37........................299.51 lbs .............-8.86 lbs
  • weskc35k
Posted January 01, 2007 - 09:21 PM
RC30 have you done anything to the thermostat i took my thermo housing out and made a y piece was 100grams lighter or something nearly 4 ounces.
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
  • Hot  60 replies
  • 22 replies
Honda XR650L 2017
  • 0 reviews
