Ciao from Italy
291 replies to this topic
  • RC30
Posted December 14, 2006 - 09:14 AM
#61
The battle of the weight.......#19
Posted Image Stock 11.057 lbs
Posted Image Special 9.493 lbs
Front fork (right), '03 CRF450, Ohlins supermotard spring, WP oil, 1" shortened.
Weight -1.564 lbs :thumbsup:
Total dry weight (verified) stock 308.37 lbs
After step #19........................300.266 lbs .............-8.104 lbs
  • RC30
Posted December 15, 2006 - 08:39 AM
#62
The battle of the weight.......#20
Posted Image Stock 0.693 lbs
Posted Image Special 0.726 lbs
Front wheel pivot, RaceTechItaly.
Weight +0.033 lbs [COLOR="Red"]PROVISIONAL?[/COLOR]
After step #20........................300.299 lbs .............-8.071 lbs
  • BWB63
Posted December 15, 2006 - 02:36 PM
#63
Just think this bike can lose 3+ pounds going to a T4 exhaust system, or header and a R4 muffler.
  • RC30
Posted December 16, 2006 - 10:31 AM
#64
Ciao Bwb63, sorry but I have bought an exhaust system which the pictures I will post later.
But the 3 pounds that I can loose are very intresting.
Can you tell me the exactly weight of these components and the links what I can see its?
Thank you and ciao.
Piero
  • RC30
Posted December 16, 2006 - 10:59 AM
#65
The battle of the weight.......#21
Posted Image Stock 0.231 lbs
Posted Image Special 0.275 lbs
Lower fork protector (left) carbon fiber, Wave Racing Italy.
Weight +0.044 lbs :thumbsup: [COLOR="Red"]PROVISIONAL[/COLOR]
After step #21........................300.343 lbs .............-8.027 lbs
  • BWB63
Posted December 16, 2006 - 11:01 AM
#66
I weighed the stock exhaust and the an XR's Only Header with a White Brothers R4, both on a postage scale. There is right at 3 pounds difference. The T4 header might be lighter but, I think the R4 muffler is close to the lightest outthere.
  • weskc35k
Posted December 16, 2006 - 06:07 PM
#67
All the street legal stuff is the same as the Aussie version wich comes in at 136kg(299lb)ADB mag scales and i have taken at least 8KG(17lb 8 ounces) at last weigh in at 127.5kg(280.5lbs).
This guy RC30 has given me a new perspective.
RC30 what about an alloy sidestand?
Good stuff RC ciaio bello.
  • RC30
Posted December 17, 2006 - 06:13 AM
#68
Thank you BWB63, 3 pounds are more what I removed.
Ciao weskc35k you have an off-road version, isn’t it?
280.5 lbs..............is a weight like mine, I can do it through a long and expensive way, like I am showing to you.
How did you do?
Alloy side stand? This is very interesting, but usually, when I am starting my engine, I stand up on foot pegs than I will have afraid about confidence, but a titanium side stand........
In any case I will cut it about 1 inch because my bike is SM version and it is little shorter than off road version and than it will be some grams more lighter...........
Ciao and see you later. Piero
P.S. Do you understand what I have written?
  • RC30
Posted December 17, 2006 - 10:33 AM
#69
The battle of the weight.......#22
Lower fork protector (right) carbon fiber, Wave Racing Italy.
Weight +0.044 lbs :thumbsup: [COLOR="Red"]PROVISIONAL [/COLOR]
After step #22........................300.387 lbs .............-7.983 lbs
  • RC30
Posted December 18, 2006 - 10:39 AM
#70
The battle of the weight.......#23
Posted Image Stock 0.055 lbs
Switch rear brake bracket, removed.
Weight -0.055 lbs :thumbsup:
After step #23........................300.332 lbs .............-8.038 lbs
  • RC30
Posted December 19, 2006 - 10:25 AM
#71
The battle of the weight.......#24
Posted Image Stock 0.088 lbs
Posted Image Special 0.057 lbs
Switch rear brake, hydraulic type.
Weight -0.031 lbs :thumbsup:
After step #24........................300.301 lbs .............-8.069 lbs
  • RC30
Posted December 20, 2006 - 10:18 AM
#72
The battle of the weight.......#25
Posted Image Stock 0.077 lbs
Posted Image Special 0.035 lbs
Rear brake fluid tank, Brembo.
Weight -0.042 lbs :thumbsup: [COLOR="Red"]PROVISIONAL?[/COLOR]
After step #25........................300.259 lbs .............-8.111 lbs
  • weskc35k
Posted December 20, 2006 - 09:25 PM
#73
RC30 the pipe and muffler are where a big weight loss is found as the stock stuff is heavy.
Yes i do understand what you have posted.
CIAIO
  • TriFire
Posted December 21, 2006 - 04:59 AM
#74
Just buy your self a Husaberg TE610 and save your self the trouble....
  • lorenzo
Posted December 21, 2006 - 06:20 AM
#75
Ciao RC30
O non ti bastava XRItalia pure quà li ammorbi con i grammi/libre, comunque bel lavoro complimenti.
Bye from
Lorexxx di XR-Italia
Lorenzo of thumpertalk
  • RC30
Posted December 21, 2006 - 01:02 PM
#76
Ciao TriFire, the Husaberg is a very good bike, but........
.............I LOVE XR :thumbsup:.
.........have taken at least 8KG(17lb 8 ounces).........
Ciao weskc35k, with an after market pipe and muffler I can lose 3 pounds, how did you do to lose the other 14,8 lbs from your bike?
I’m very curious!
Ciao Lorenzo..................:devil:
  • RC30
Posted December 21, 2006 - 01:26 PM
#77
The battle of the weight.......#26
Posted Image Stock 0.127 lbs
Posted Image Special 0.048 lbs
Rear brake fluid tank pipe, shortened.
Weight -0.079 lbs :thumbsup: [COLOR="Red"]PROVISIONAL?[/COLOR]
After step #26........................300.18 lbs .............-8.19 lbs
  • BWB63
Posted December 21, 2006 - 01:52 PM
#78
Skid plate is one pound and it's not needed for the street.
  • RC30
Posted December 21, 2006 - 02:14 PM
#79
Please, wait few steps...........:thumbsup:
  • weskc35k
Posted December 21, 2006 - 02:21 PM
#80
All the rego gear came off ,sprockets,subframe extension,muffler,overflow bottle,side stand,heat guard on the header,used lighter bolts and nuts,stuff like that.
RC30 whar was your nett loss with the new front end?
CIAO BELLO
  • Hot  186 replies
  • Hot  60 replies
  • 3 replies
Honda XR650L 2017
  • 0 reviews
  • 9 replies
