Ciao from Italy
291 replies to this topic
  • RC30
Posted December 05, 2006 - 09:48 AM
#41
The battle of the weight.......#10
Posted Image Stock 0.455 lbs
Posted Image Special 0.121 lbs
Rear tail light, vintage.
Weight -0.334 lbs :worthy:
Total dry weight (verified) stock 308.37 lbs
After step #10........................303.642 lbs .............-4.728 lbs
  • RC30
Posted December 06, 2006 - 07:47 AM
#42
The battle of the weight.......#11
Posted Image Stock 0.557 lbs
Posted Image Special 0.275 lbs
Turn signals, Kellerman.
Weight -0.282 lbs :worthy:
After step #11........................303.36 lbs .............-5.01 lbs
  • RC30
Posted December 07, 2006 - 09:05 AM
#43
The battle of the weight.......#12
Posted Image Stock 0.052 lbs
Rear reflector, removed.
Weight -0.052 lbs :worthy:
After step #12........................303.308 lbs .............-5.062 lbs
  • Fingers
Posted December 08, 2006 - 12:56 AM
#44
Hey RC, come vai, abitato in Italia 4 anni fa (in Puglia vicino Taranto, erano un scambio fra La Marina Italiano/USMC)..... lo manco tanti, particlaramente la cucina. Your dry weight seems high, 32+ lb more than stock, is that all from the starter and SM wheels?
  • RC30
Posted December 08, 2006 - 10:29 AM
#45
The battle of the weight.......#13
Posted Image Stock 2.063 lbs
Posted Image Special 1.325 lbs
Handlebar double diameter, X-Fun.
Weight -0.738 lbs :worthy: [COLOR="Red"]PROVISIONAL[/COLOR]
After step #13........................302.57 lbs .............-5.8 lbs
  • RC30
Posted December 08, 2006 - 12:28 PM
#46
Ciao Fingers, my compliments for your good italian, you have nostalgia for Italy, isn’t it?
I will tell you that the Honda declare for US offroad version about weight is 277lbs (www.powersports.honda.com), meanwhile for Europe offroad version is 275lbs (www.dallarahonda.com).
The difference of the weight of two models is wrong, because in Europe the XR650R is street legal than there are more parts: a big (and heavy) front lamp, turn signals, rear view mirrors, an additional rear tail light, rear sub fender, rear sub frame and at least for Italy rear passenger pegs.
The weight of all these parts is about 10lbs (I have checked it), so the declared weight should be 287lbs (277+10).
And then what is wrong?
I don’t know how Honda weighs its motorbikes, without lubricant? Without liquid cooling? Without brake fluid? Without air in inner tubes? Or without wheels?.............
And I don’t know what scales they used.
However I can weigh it with two little scales, in stock configuration (like pictures of post #8) without gas only (dry weight) I’ve checked 308.37lbs (147.58 front + 160.79 rear).
By the way, my bike is SM version so about 6.5lbs more heavy to offroad version.
I post some tests makes from reliable italian magazines:
Motociclismo 8/2000 offroad version
137kg (65+72) = 301.76lbs (143.17+158.59)
Motociclismo 5/2004 supermoto version
140kg (67.2+72.8) = 308.37lbs (148.02+160.35)
Motociclismo Fuoristrada 6/2003 supermoto version
140kg (67+73) = 308.37lbs (147.58+160.79)
Let you see the supermoto weights are seems to mine and the offroad model is 6.6lbs lighter than the SM model, at the end I believe in all this data.
Sorry frankstr if I don’t translate these pages , but I’ve encircle the interesting data..........
P.S. My bike hasn’t the electric starter (useless weight…….)
Ciao Piero
  • RC30
Posted December 09, 2006 - 09:42 AM
#47
The battle of the weight.......#14
Posted Image Stock 1.79 lbs
Posted Image Special 1.832 lbs
Fork top bridge, RachTechItaly.
Weight +0.042 lbs [COLOR="Red"]PROVISIONAL[/COLOR]
After step #14........................302.612 lbs .............-5.758 lbs
  • hypersthenos
Posted December 09, 2006 - 11:32 AM
#48
Yes, I've noticed that nearly all aftermarket triple clamps are a bit heavier than the stock ones (if they are aluminum). Only justification for new ones are more strength or change in bar location or steering dampener mount. They are more expensive & look nicer though!
  • RC30
Posted December 10, 2006 - 10:01 AM
#49
.....Only justification for new ones are more strength or change in bar location or steering dampener mount........
......they are more stiff, more wide (about 3/4") for supermotard use, they allow change the offset (0+5mm) and they’re more heavier than stock because there are more ergal material too.
.....They are more expensive.......
:worthy:
  • RC30
Posted December 10, 2006 - 10:12 AM
#50
The battle of the weight.......#15
Posted Image Special 0.651 lbs
Risers, ?.
Weight +0.651 lbs [COLOR="Red"]PROVISIONAL[/COLOR]
After step #15........................303.263 lbs .............-5.107 lbs
  • RC30
Posted December 10, 2006 - 11:10 AM
#51
Sorry, I have used two times this smilie but............what do it mean (&%$#@!)?.....:worthy:
  • motomonte
Posted December 10, 2006 - 11:50 AM
#52
What The &%$#@!...
  • RC30
Posted December 10, 2006 - 12:09 PM
#53
:worthy:............................:D
Thank you motomonte..........
  • RC30
Posted December 11, 2006 - 09:36 AM
#54
The battle of the weight.......#16
Posted Image Stock 3.436 lbs
Posted Image Special 3.127 lbs
Lower triple clamps, RachTechItaly.
Weight -0.309 lbs :thumbsup: [COLOR="Red"]PROVISIONAL[/COLOR]
After step #16........................302.954 lbs .............-5.416 lbs
  • RC30
Posted December 12, 2006 - 09:48 AM
#55
The battle of the weight.......#17
Posted Image Special 0.231 lbs
Steering pivot, RachTechItaly.
Weight +0.231 lbs
After step #17........................303.185 lbs .............-5.185 lbs
  • Beelzeboss
Posted December 12, 2006 - 10:25 AM
#56
This is madness,madness i tell you
  • atreiou
Posted December 12, 2006 - 11:28 AM
#57
And You don't know how the story ends.. hehe
  • RC30
Posted December 12, 2006 - 12:25 PM
#58
:devil:...................................:thumbsup:
  • Maroast
Posted December 12, 2006 - 04:32 PM
#59
I too know how the story ends! :smirk:
.......It ends with me eventually knowing how the story ends.....or some crap like that....
  • RC30
Posted December 13, 2006 - 11:08 AM
#60
The battle of the weight.......#18
Posted Image Stock 11.288 lbs
Posted Image Special 9.933 lbs
Front fork (left), '03 CRF450, Ohlins supermotard spring, WP oil, 1" shortened.
Weight -1.355 lbs :thumbsup: [COLOR="Red"]PROVISIONAL[/COLOR]
After step #18........................301.83 lbs .............-6.54 lbs
  • 4 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
  • 22 replies
  • 17 replies
