New 06' runs like sh..!
5 replies to this topic
  • lirider75
Posted September 27, 2006 - 05:31 PM
I have know idea what to do any more. Brought it to the dealership at least 4 times. Sorry 2 say I`m not that smart when it comes to this. My yamaha yfz450 misses,pops,and stalls all the time.This is with no mods!!!!! Any help would be very greatfull!!!!!!!!!!!!!
  • bboyce
Posted September 27, 2006 - 05:34 PM
Is this a quad since you say YFZ?...or did you mean YZ/F..ill assume YZ/F.
Dude, find a new dealer, obviously your dealer knows nothing. either your jetting is off, or your valves need adjusted...also, if there was gas in the carb for awhile, it might be gummed up, so you might have to clean your jets...its not that hard man. but good luck.
  • flintlock28
More than likely, it's a jetting/Carbuerator issue. What is the elevation that you ride at??
  • MX1967
Posted September 27, 2006 - 08:43 PM
My 06 YZ popped, blurbled, & liked to stall until I fattened up the pilot jet ( I think I installed a 48 ) & now it runs great!!
  • stroker101
Posted September 27, 2006 - 10:09 PM
same here. had dealer c/o the slow jet in febuary. installed a #48...runs fine now :thumbsup:
  • Ga426owner
Posted September 28, 2006 - 06:00 AM
you need to rejet it.....it is way too lean and the air/fuel screw needs adjustment -
buy a 45 and 48 pilot jet and a 165,168,170 mainjet and a Adj fuel screw.....you will need to get smarter on jetting and adjusting the fuel screw in order to get your bike to run right.....do a search on both here for this forum
start with the 45pj and 168mj and just under 2 turns out on the fuel screw
  • Hot  113 replies
  • Hot  38 replies
  • Hot  36 replies
