Do I need a Blue needle jet
2 replies to this topic
  • MN_Paul
Posted September 27, 2006 - 05:24 PM
I was going to install a JD jet kit, but found out it already had a RED needle in it. Is it worth having the blue needle, or can I save some money by just using the red one. I took a look at the jetting database and it seems split between blue and red.
2005 WR450,
0-1000ft,
moderate to high humidity,
55-85 degrees.
TwinAir filter, modified airbox, opened stock exhaust (might get a FMF-Q2).
I already picked up a 168 main and a 48 pilot.
Thanks,
Paul in MN
  • Indy_WR450
Posted September 27, 2006 - 06:04 PM
You will be fine with the red. Use clip positions 4 for summmer and 5 for cooler weather. Use clip # 6 only if you ride below 45 degrees. :thumbsup:
  • Few
Posted September 27, 2006 - 07:08 PM
Indy, you are the MAN! :lame: nice post for us rookie's at jetting. I have only owned/ridden my 450 for a short time (riding time/work/kids/wife...availability) and needed to have that little confirmation that things were working for this bike as required by my rigorous standards.
I too run the red with no complaints thus far. :p
