Here's how to fix wr450 starter
7 replies to this topic
  • Nate_R
Posted September 27, 2006 - 03:10 PM
I just fixed my 04 wr450 starter motor that went bad. The starter new is around $260. It's actually not that hard to fix. The brushes were worn out and just needed replacing. If anyone has the same problem you can get new brushes for around $17.00 shipped to you. The brushes are $10 and the shipping cost me $7 to florida. The brushes can be ordered from stocker's starters @1-888-786-2537. The part number is B-16 brushes and tell them it's for a yamaha wr450. I called many places that rebuild starters and none of them had brushes available except these guys. The manual tells you how to remove the starter. All you do is remove the header, and 3-way oil line, and then pull the two bolts for the starter. Remove the starter and unbolt the 2 bolts holding it together. Separate the starter and pull off the end caps. You'll see two brushes. One is screwed and the other sodered. You'll have to re-soder the one. It's a bit tricky getting it back together as the springs keep pushing out the brushes. You have to push them in all the way, holding them with your fingers, and put the rod in as far as you can and have it press on top of the brushes. Then you use some kind of pick and pry one brush all the way in and slip the round rod thing down past the one brush. Then use the pick to do the other brush and close the starter up and bolt it back together. Then reinstall. If this is too hard, there are usually local places that will change the brushes for you for $40-75. Hope this helps someone. :thumbsup:
  • tony1970
Posted September 27, 2006 - 03:59 PM
Thanks for the info. I am guessing that the starter did not change that much to the 05's.
  • LimyWPom
Posted September 27, 2006 - 06:37 PM
Nate, good post. you can bet your life that will help somone.
  • LimyWPom
Posted September 27, 2006 - 06:39 PM
Nate, good post. you can bet your life that will help someone.
  • Thumper_Bloke
Posted September 27, 2006 - 07:04 PM
Thanks! I use my starter alot. Its not called the magic button for nothing! :thumbsup:
  • Beejay
Posted September 27, 2006 - 07:25 PM
Thanks that is going to help in the near future, good one!
  • Bosco83
Posted September 28, 2006 - 06:34 PM
I did that to mine but still didn't work dangit I bought my brushes from the dealer and they were only $12.50
  • BIGchiefKODIAK
Posted September 28, 2006 - 09:41 PM
going to call them. thanks.
