BR8EG or BR8ES?
22 replies to this topic
  • KAS
Posted September 26, 2006 - 06:39 AM
Is it OK to run a normal ol' BR8ES plug in a YZ250? The bike came with a BR8EG, which from what I can tell is just a "racing" plug that costs 3 times what a normal plug does.
  • husabutt
Posted September 26, 2006 - 07:06 AM
The "ES" is a non-resister plug. It could damage your CDI unit. I have a 92 Cr250 and always went cheap on the plugs, "ES", so far it hasn't hurt anything but any professional tuner will tell you not to run them.
  • rmz757
Posted September 26, 2006 - 07:30 AM
actually i believe the R in br8es and eg shows that it is a resistor plug.
  • 4strokes4me
Posted September 26, 2006 - 07:44 AM
"R" is for resistor.
The "S" is for standard, and the "G" is the first step up the money ladder for NGK spark plugs.
As far as CDI damage, Eric Gorr stated that the resistor plugs made no difference. It is somewhere on his site, or you can look in one of his books.
  • DLHamblin
Posted September 26, 2006 - 08:51 AM
Yes you can run them. Technically (at least according to NGK) the BR8EG resists fouling better than the BR8ES.
When I didn't have a BR8EG around I have run them and to be honest couldn't tell the difference.
  • RCannon
Posted September 26, 2006 - 10:22 AM
I know the EG should resist fouling better. It costs twice as much, etc. Seriously the only plugs I ever cold foul are EG's. I like the BR8ES plug just fine. I found several cases of them last year for 10 cents each. I sold most of them but kept enough of them for me.
Actually, even the EG is not really a high dollar plug.They are a "step-up" but nothing too special. NGK has some that work in our bikes for 25-30 bucks. They do consider these high-dollar.
  • husabutt
Posted September 26, 2006 - 11:06 AM
Frequently Asked Questions
Q: When should I use a resistor spark plug?
A: NGK "R" or resistor spark plugs use a 5k ohm ceramic resistor in the spark plug to suppress ignition noise generated during sparking.
NGK strongly recommends using resistor spark plugs in any vehicle that uses on-board computer systems to monitor or control engine performance. This is because resistor spark plugs reduce electromagnetic interference with on-board electronics.
They are also recommended on any vehicle that has other on-board electronic systems such as engine-management computers, two-way radios, GPS systems, depth finders or whenever recommended by the manufacturer.
In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion.
  • KAS
Posted September 26, 2006 - 12:39 PM
Thanks guys. I'm gonna stick with BR8ES. Five bucks a plug for the EG is a little silly.
  • RCannon
Posted September 26, 2006 - 01:06 PM
My local shop charges 5.00 for the es. MAILORDER RULES!!! Try the tt store and see how cheap these plugs really are.
  • kx_rider53
Posted September 26, 2006 - 02:30 PM
I used to run the EG, but switched to the ES b/c its cheaper. No problems here.
  • KAS
Posted September 26, 2006 - 03:55 PM
My local shop charges me like two bucks for the "ES".
  • RichBaker
Posted September 26, 2006 - 04:49 PM
Nope, the R in BR indicates that it IS a resistor plug....look here for a downloadable chart from NGK.
http://www.ngksparkp...1200&country=US
  • husabutt
Posted September 26, 2006 - 07:04 PM
"The "ES" is a non-resister plug" I still believe that statement to be factual. Nope to what?
  • CFM-Z440
Posted September 26, 2006 - 08:24 PM
How about the BR8EYA?
I work at a snomobile shop, and we swap BR9EYA's into sleds all the time where a BR9ES is supposed to be. Whats the difference?
  • radsdad
Posted September 26, 2006 - 09:03 PM
OK-here goes. B=14mm thread diameter---R=resistor---EG=V grooved nickel alloy center electrode--- ES=standard 3/4 inch reach center electrode. So, a B8ES is a non resistor plug. A BR8ES is a resistor plug. The EG is less prone to fouling, according to NGK. I have found the opposite to be true. I like the ES plugs. I get them at the auto parts store for 99 cents.
  • DLHamblin
Posted September 27, 2006 - 03:35 AM
An "R" after the letter designation indicates a resistor plug. So the BR8ES is a resistor plug.
The ES or EG signifies what electrode type is used. ES is standard electrode, EG is fine wire type.
As mentioned go to the NGK site and they have a nice chart that explains it.
http://www.spark-plu...ical/ngkjpg.htm
  • scottmotox
Posted September 27, 2006 - 03:43 AM
i agree with that
  • CALEB1
Posted September 27, 2006 - 02:28 PM
If Your Store Is Charging 5.00bucks For An Es You Need To Find A New Store, I Am The Parts Guy At Mine And An Es Is 2.50, No Shipping Like You Would With Mail Order
  • RCannon
Posted September 27, 2006 - 03:04 PM
I did find a place to beat the price. I bought three cases of Br8EG's for .25 cents each.
The local shop will hammer you on your way out to ride or somehting like that. You need a bottle of Yamalube R and a goggle lens, lets say.
You stop in and your mind starts to wonder..."How am I doing on plugs......."
Hey, throw a couple of the Br8es's in , please"
Look at final bill and realize he hammered you 4.99 each for them. However, he did give you the "10% racers discount". LOL They did me this way ONCE.
I drove 30 miles to buy my 2006 yz 250 when these folks are 2 miles away. Hope they enjoyed the extra buck on the plug.
I also think the "Y" in the BR8EYA stands for ..."Charge them two bucks more because its too cold to be riding in the snow."
  • husabutt
Posted September 27, 2006 - 03:53 PM
I see said the blind man.
YZ-125.. Crank Case drain plug shattered + more issues.. by david.suggs
  • Hot  25 replies
Should a 2stroke idle by TTRpaul
  • Hot  45 replies
yz85 overhaul - shopping list? by booyaga
  • 18 replies
I am 105 pounds and 5' 3" can i ride a yz250 or yz250f? by Longlive2strokes
  • Hot  35 replies
Favorite vintage dirt bikes by ToadilyInsane
Dirt Bike   Special Interest Forums   Vintage
  • Hot  34 replies
