Sunline Foot Pegs Dont Fit ?? At Least Mine Dont
5 replies to this topic
  • dwnlowx
Posted September 25, 2006 - 10:35 PM
I Just Got A Set Of Sunline Foot Pegs 57mm Stainless And The Holes Dont Line Up On Either Side Any Feed Back Would Be Great Thanks
  • Satch0922
Posted September 26, 2006 - 03:01 AM
are you sure you received the correct pegs for your bike? If so, then you will just have to work with it...sometimes its a chore to get the springs slightly compressed to get the holes to line up.
  • Ga426owner
Posted September 26, 2006 - 05:00 AM
See if they line up w/o the spring on them first...if they do, they fit.....some can be a real pain to get on.....
  • TapptOut
Posted September 26, 2006 - 06:21 AM
Should have bought fastways.
  • SCIENCE
Posted September 26, 2006 - 07:38 AM
Check the p/n first and verify with them that they are the correct ones for your bike. If they are, use a punch/screwdriver or the like from the bottom to line up the holes. Then slide the pin in as you pull the punch/scewdriver out. Install the washer and cotter pin and you're set. I usually put some waterproof grease on the pins as well.
  • dwnlowx
Posted September 26, 2006 - 10:38 AM
well i tried again again again now this is crazy i can put the slidder bolt threw the peg back wards but the top whole is not linng up or am i doing something wrong its the same on both sides
  • Hot  47 replies
  • On January 15, 2017
  • Hot  36 replies
