Problem installing handguards
13 replies to this topic
  • Dazza83
Posted September 25, 2006 - 08:02 PM
Hey guys,
First time poster, longtime reader :thumbsup:
I have just bought a brand new WR450F here In Australia. I've taken it on a first ride and loved it - haven't had the chace to get back on it yet though.
One thing I have tried to do is install the handguards that come with it and I've had nothing but problems. Has anyone else had drama's installing them? my problem seems to be the nut at the end of the bolts won't fit into the handlebar no matter how hard I try - is there a secret for this? Obviously I have no instructions for it so I was wondering how you guys have managed to do it and if so, how? Also what are the two plastic tubes for?
Thanks in advance,
Daz.
PS I did a search before asking and couldn't find anything of help.
  • jbrooks26
Posted September 25, 2006 - 08:34 PM
Are you tightening it before you install it into the bar? It must be loose, it is an expansion fitting that secures it to the inside of the bar. Hope this helps.
Josh
  • Dazza83
Posted September 25, 2006 - 11:05 PM
Josh,
no I am not tightening it before putting it into the bar as I am aware they work by expansion. Reason why I am so confused about it is that its the handguards that come standard with the WR450F in the package. My handlebars are stock etc which is why I'm suprised they don'tall fit and match up together....
Thanks for your help anyways,
Daz
  • jbrooks26
Posted September 26, 2006 - 01:01 AM
Are you saying it is too large to fit into the bar? I don't guess I understand what you are having trouble with. Could you post some pics? Sorry I couldn't help any more.
Josh
  • gregwr450f
Posted September 26, 2006 - 01:27 AM
get your dealer who you bought it off to put your bike together before he sells.
  • SID013
Posted September 26, 2006 - 02:42 AM
Mine came with the handguards installed already & have had them off & on several times with no dramas. You have the original Renthals on the bike right? I have changed over to TAG T2 Metals now & aftermarket handguards & no problems fitting them either. I'm with GregWRF450 take the bike back to your dealer & get them to fit them.
Cheers
  • Dazza83
Posted September 26, 2006 - 04:38 PM
Yeah this is the last resort before going back to the dealer - just thought I'd ask in case its a common prob - obviously not.
Thanks anyways guys,
have a good one
Daz.
  • MountainMax
Posted September 26, 2006 - 04:43 PM
Well they don't come with them here, I bought an aftermarket set and put on mine, they fit no problem either, but you should post some pics, and maybe the nuts are for the larger pro taper bars like on the yz's
  • Dazza83
Posted September 27, 2006 - 12:42 AM
Of interest, I looked and sure enough in a completely random unrelated plastic bag were the correct sized nuts. Got the left one on no drama's.... now I am trying to work out the right hand side (throttle) guard... as you would know the hole is smaller and the metal stuff won't fit through. I'm guessing a bit of drilling to widen the hole is required coz I've looked and there is no smaller nuts. Is that a correct assumption?
Just wanted to ask before I did and farked the thing int he process....
Thanks
Daz.
...seems something so simple is causing me a few problems damnit!
  • jbrooks26
Posted September 27, 2006 - 01:13 AM
I assume you are talking about the hole in the throttle tube. With most hand guards you cut this off with a hack saw. Just cut enough to remove the end of the tube and you will be good to go. Hope this helps.
Josh
  • MountainMax
Posted September 27, 2006 - 02:28 AM
Yes, I too had to trim my tube a small bit.......
  • Dazza83
Posted September 27, 2006 - 05:40 PM
Thanks again,
Yes I got the drill out and drilled the existing hole to a much larger side (instead of hacksawing the whole end off) and it worked just fine.
I've now got them both installed to my liking. Couldn't believe something to simple caused me so many drama's!
Anyways, I think today is a good day for a ride... seeya.
Cheers,
Daz.
  • storm 800
Posted September 27, 2006 - 06:30 PM
Did your WR come with the pro tapers on it! My handgaurds need a adapter to make them fit verses regular bars.
  • LimyWPom
Posted September 27, 2006 - 06:31 PM
Dazza,
It sounds as though the first bolt size suplied was the type for steel bars as the interior hole in those is bigger than the Aluminium, did the same thing myself with the first handguards I bought.
