Clutch not fully engaging
5 replies to this topic
  • MerlinUK
Posted September 24, 2006 - 11:22 PM
I went for a ride yesterday, and noticed my clutch was not engaging fully, IE, i could come to a stop in 1st with the clutch all the way in, but the bike was still pulling forward slowly.
I've had a search to see if this is normal, but can't really find a definitive answer. Any advice would be greatly appreciated.
  • PBDBLUE
Posted September 25, 2006 - 02:13 AM
Are you having any trouble shifting? If it's just a little drag then it is probably normal but more than that most likely means the clutch plates have warped (the metal ones). I had this happen on my '04 WR after abusing the clutch severely on a ride. In my case the bike would not shift well and wanted to stall the engine when stopped. Remove the plates and check them. They should be perfectly flat. The spec is in the owners manual.
  • MerlinUK
Posted September 25, 2006 - 05:21 AM
I have no trouble changing as such, the bike has stalled a few times when slowing down/coming to a stop, i just put it down to my riding. I might swap out the plates anyway, its not gonna do any harm :thumbsup:
  • SJMC_DON
Posted September 25, 2006 - 07:04 AM
There is a thread called "Clutch Problem" it was last posted to a couple days ago....... it has your answer and the good news is it is a cheap and easy fix :thumbsup:
  • MerlinUK
Posted September 25, 2006 - 07:39 AM
Superb, i'll give that a go at the weekend :thumbsup:
  • hotthrottle613
Posted September 25, 2006 - 08:38 AM
Go to www.thumperfaq.com, click on .79 cent fix. :thumbsup:
