650L head gasket for a big bore 600?
2 replies to this topic
  • rg_series
Posted September 24, 2006 - 03:07 PM
would it be okay to use a 100mm 650L head gasket in a 100.5 mm bore xr600? Honda might have an oversize gasket, but other than size are the two gaskets alike? Thank in advance.
  • cleonard
Posted September 25, 2006 - 11:35 AM
I'm not sure. I know that the XL600 has a 100mm bore and those will work. A call to XRsonly should answer your question. They sell XR600 gasket kits for 98,100,101, and 102 mm pistons.
  • rebelventurer
Posted September 25, 2006 - 02:47 PM
Call Kamell at www.albakersxrsonly.com ph.#760-244-2626 he will give you the right info. Don't play around guessing or taking anyones advise that is guessing, you blow up your spending big bucks. I do reccomend using Cometic gaskets for the xr600, Good Luck!!!!
