what is uncork?
22 replies to this topic
  • TexasXR650L
Posted September 24, 2006 - 02:27 PM
what exactly is uncorking the air box? what would i be looking for, do i need to buy anything, how do i do this, will there be a change on a stock bike by doing this, and is it a "cork"? lots of info needed here. thanks :thumbsup:
  • rebelventurer
Posted September 24, 2006 - 04:32 PM
First thing you need is a good quality corkscrew one that wont allow any cork to fall into the carburator! LOL just kidding.
The bike comes jetted lean and quiet to meet the epa's noise and pollution requirements. To "uncork" a xr650l you will need to spend some money, an exhaust system is pretty much mandatory as well as a jet kit, which will compensate for the added airflow, at that point you can remove the snorkel from the top of the airbox, just drill out the two rivets that retain it. Also you can drill out the left side panel if desired, where it covers the air box. also you can get a emissions block off kit that will allow you to remove the smog pump.
IMS makes a good block off kit
Dynajet makes a good jet kit that includes spring for the slide main and pilot jets and new needle.
also reccomended is a K&N air filter
White Brothers E2 exhaust seems to be the preffered exhaust system, though I have a FMF powercore4 and stainless header, but it is on the loud side of exhuasts.
Mostly though if you dont know what your doing find someone who does though I would not take the bike to a Honda dealer for these kinds of modifications. You can probably find someone through thumpertalk who is nearby. Good luck, These bikes can be totally transformed with a few good modifications! :lame: :thumbsup:
  • TexasXR650L
Posted September 24, 2006 - 04:51 PM
the snorkel is already missing, what will this do? :thumbsup:
  • rebelventurer
Posted September 24, 2006 - 04:56 PM
Bike will run a little hotter and leaner. does it still have the smog pump? Do you know if the carb has been rejetted? Myself I would at the very least go up one main jet size even with the stock exhaust, your better off being slightly rich on mixture than too lean. Give me five minutes and I will post the stock main jet size on this thread.
  • TexasXR650L
Posted September 24, 2006 - 05:03 PM
100 % stock but the snorkel is gone, this cant hurt the bike can it, can i use my gas mixture screw and richen it up a little? and yes smog stuff is still there, no rejet either, stock exhaust
  • rebelventurer
Posted September 24, 2006 - 05:07 PM
If my eyes arent totally shot I believe the stock jet is a 155, my Dynajet kit came with a 160 which is two up from stock and a 165 four up, I am using the 165, If you want I will send you the 160 but please do not blame me if you mess up, once again taking a carb apart is not hard but if you have no experience with it get some help.
  • TexasXR650L
Posted September 24, 2006 - 05:13 PM
i build small block v8s with my eyes closed. ill be ok. read over daves mods and they dont look to hard, just time consuming
  • rebelventurer
Posted September 24, 2006 - 05:17 PM
You can everything you need to uncork your bike on ebay under search xr650l. most of my uncork stuff came from there, with no problems.
I do not know what a honda dealer would charge for a jet or if they even would have one in stock but I would definetly go up a size or two, and if you do not have inspections in Texas get rid of the smog pump, and you will get rid of all the popping and sputtering the bike does now. even if you do have inspections there are ways around that. that local inspection, gas station, not the bike shop, are likely not to know much about this particular bike. Good luck. :thumbsup:
  • rebelventurer
Posted September 24, 2006 - 05:22 PM
If you can build a small block you can do anything to your L model, by all means get you some parts and uncork her, she will thank you by giving you a hell of a good time. I will not make any analogies here but several involving women come to mind. :thumbsup: :lame:
  • rebelventurer
Posted September 24, 2006 - 05:25 PM
I have not seen daves mods, but heard a lot, I do not know what it is about drilling the slide Ive heard I did none of that just the jet kit my bike runs great, though I would probably read it if I knew where to find it? :thumbsup:
  • TexasXR650L
Posted September 24, 2006 - 05:42 PM
I have not seen daves mods, but heard a lot, I do not know what it is about drilling the slide Ive heard I did none of that just the jet kit my bike runs great, though I would probably read it if I knew where to find it? :lame:
go to 4strokes.com and look under tech for hondas, hihs carb mods are in there, dosent look hard, just time consuming :thumbsup:
  • rebelventurer
Posted September 24, 2006 - 05:58 PM
Read it I think drilling the slide is the same as replacing the slide spring with a lighter spring, other than that I think I have it covered, it took me about 30 minutes to remove carb install kit and put the carb back on, I did not remove the tank or seat to do it just the rear brake fluid container (res). I notice the profile of the needle that came in the kit was different and is adjustable with a e clip and notches instead of washers from a hardware store! :thumbsup:
  • XR650L_Dave
Posted September 25, 2006 - 07:54 AM
Putting in a lighter slide spring opens the slide more for a given airflow rate, and makes the slide open only slighty faster.
Drilling the holes allows the air to get sucked out from above the slide faster, meaning the slide will open(rise) sooner when the throttle is opened. Drilling the slide has a much larger effect than changing the spring.
Dave
  • Few
Posted September 25, 2006 - 11:31 AM
When you take out the 155 and exchange it for Rebelventurer's 160 could you send me the 155? I have the stock 152 in my XR600, It's to lean.
Pm me? Thanks.
  • rebelventurer
Posted September 25, 2006 - 01:47 PM
OK, excuse me! My eyes are shot the stock jet is a 152.5 And if you want the 160 cause yours is too lean pm me I will send it to you.
I need to get a cup and do the " help for the blind" thing.
Why do they make them numbers so small anyway? I guess I need one of them magnifying glasses. And hey a 2 does look like a 5 if you turn it upsidedown. :thumbsup: :lame: :p
  • rebelventurer
Posted September 25, 2006 - 01:55 PM
So Dave, if I drill my slide in conjunction with that lighter spring is that going to get rid of the off idle hesitation, and was those holes 3/32" or 5/32"? Remember I am blind 2's look like 5's especially when they are stamped in brass!
Or is that hesitation only going away with a pumper carb?
I appreciate the info, you have moved my opinion of yankees two notches above them banjo playing alabamans, or is it alabamians. Sincerely Thanks! :thumbsup: :lame: :p :bonk: :eek: :bonk:
HEY, look its a six pack!!!
  • kelleyseiler
Posted September 26, 2006 - 05:28 AM
Here is the video of Chicagobikefan doing Dave's Mods :lame: Just click on the link.
http://www.thumperta...ght=Dave's mods
  • XR650L_Dave
Posted September 26, 2006 - 07:47 AM
Drilling the slide, with or without the new spring, will go a long ways towards removing the hesitation.
Still, even with that, when you crank the throttle open the slide will take 1/2-sec or so to open all the way. This can be a good thing in low-traction situations.
The drill size is 5/32.
Dave
  • ghoti
Posted September 26, 2006 - 08:53 AM
Mine doesn't hesitate unless it's just warming up, the engine that is.
  • squatpuke
Posted September 26, 2006 - 09:47 AM
Saw the video...not sure I'm comfortable doing that...I could probably take things OUT of the bike, but (for me) puttin' 'em back is the problem.
Do you think most TT riders are doing this themselves or taking it to the shop?
Honda XR650L 2017
  • 0 reviews
  • 3 replies
  • 4 replies
  • 22 replies
Washington
  • Hot  32 replies
