cam question.xr600r
1 reply to this topic
  • timothypg
Posted September 23, 2006 - 07:56 PM
i just got my cam and valve cover back from barnums. had the cam hardwelded and ground to mid profile, rockers also welded. look good. my ? is, the cam has a grey coating on it, for protection i'am guessing. does this coating need to be removed before install? thanks. tim. p.s. any recomendations for jetting. 1986 dual carbs. i already have larger main jets due to earlier mods, 135, 3 or 4 sizes larger than stock now. 100mm piston 10.5:1, open air box, k&n. stock headpipe ceramic coating.
  • frankstr
Posted September 23, 2006 - 08:08 PM
No, Do not remove the(coating)It is a heat treat ....Install as is with proper assembly lube.....
maybe richen it a couple sizes bigger,Keep a eye on the plug color..
:thumbsup:
