06 YZ450 Jet swap??
3 replies to this topic
  • arnie230
Posted September 22, 2006 - 12:47 PM
Can the Main and Pilot jet on the '06 YZ450 be swapped without removing the Carb?
  • Reyndogg
Posted September 22, 2006 - 12:51 PM
yes, but it's a pain...remove hot start, twist as far as you can, and you should be able to get to them.
I did it once, next time i will pull the carb out unless someone has a better method :thumbsup:
  • NYMXer
Posted September 22, 2006 - 12:53 PM
You don't need to remove the hot start. I took off the rear sub frame and rear exhaust for more room but that was my choice. It didn't need to be done but since I wear bifocals it was easier for me. :thumbsup:
  • WFOracer
Posted September 22, 2006 - 01:25 PM
I swap my main and pilot all the time by just taking the drain bolt off. The main is a 6 mm he and the pilot is a flat blade....it's not rocket science. I did get the carb off once by removing the top motor mounts. It was a little bit of a pain, but not too bad.
  • Hot  36 replies
  • On January 15, 2017
  • Hot  28 replies
