03 450 brake lever, flywheel weight??
6 replies to this topic
  • zach250
Posted September 21, 2006 - 07:47 PM
Hi I just bought this 03 450. I have been told that adding a flywheel wheight will help me from stalling in turns and much more. I do mostly hill climbs and trail riding. I would like to know what brand and what size would be the best for me. I weigh 200 lbs if that matters. I would also like to get the unbreakable levers, which ones are the best and where can I get them.??? any help is greatly appreceiated thanx
zach
  • RichBaker
Posted September 21, 2006 - 08:12 PM
Don't know about brake levers, but I'm pretty sure there aren't any flywheel weights available...
  • Alley Cat
Posted September 21, 2006 - 08:25 PM
Trailtech make heavier flywheels for the WR's!
Why one would want a heavier one is beyond me?
  • Alley Cat
Posted September 21, 2006 - 08:29 PM
zach
Have a look at a recluse auto clutch.
I haven't used one, it is not for me, but I am sure it would suit you good.
As for unbreakable levers, have a look at the ASV levers.
  • Thumper_Bloke
Posted September 21, 2006 - 09:53 PM
I have the full Acerbis brushguards that protect my levers and my fingers in crashes.
Also, if i had the cash i would get the Recluse clutch.
  • jim-in-so-ore
Posted September 22, 2006 - 05:21 AM
I think that www.steahlyoffroad.com makes a weight for the WR 450s. I know he used my bike :thumbsup: to make a prototype but I don't know if it ever went into production, check his web site.
Jim
  • mtrablue
Posted September 22, 2006 - 06:44 PM
as far as levers, try some good brush guards. the kind with the aluminum bar through it. enduro engineering or something similar. loosen the clamping bolts a little so the lever spins on the bar. it also helps to wrap the bars with teflon tape where the levers clamp.
the flywheel weight will be a bit harder to come by. trailtech may have something. i had about 8 ounces added to mine and i like it. we ride a lot of very tight rocky stuff and it helps to smooth out the power. one thing to try is to turn up your idle some. experiment with what works for you. by the way, it's free!
