Hi everyone. I've been hanging around in the minibike areas but happened to pick up a rough 84 XL125-S a few weeks ago. The sign said "it runs" and it did. It's having a harder time now. We didn't do much other that start and run it. It will run for a minute or two and then is impossible to restart. The kickstarter doesn't come back up. Once running it makes a terrible racket until you pull it back up and hold it in place. I'm assuming it is probably in need of a new spring. The levers are missing and the clutch lever has been rigged with a bicycle one but it works.
I plan on taking the carb apart and giving it a good clean. I've worked on 50cc 2strokes a little. Is the carb going to be that different? Any advice on where to start? I would be happy if I could get it running well enough to teach my son how to ride and use the clutch.
I made it half-way around the block last night before it stalled. A couple of neighbor kids were walking around and saw me. They came over and marveled at "that old fashioned bike".
Thanks for any help you may have. I don't mind getting up to my elbows in grease. I usually just need a kick in the pants to get started.
TC
