Tall Guy big bar Handlebar Risers?
7 replies to this topic
  • xr650rkyle
Posted September 20, 2006 - 08:08 AM
Does anyone know where I can purchase a bolt on pair of extra tall
big bar risers? (For Aftermarket Clamps)
I am wishing for 2" high and a inch forward.
I have not found any one who makes aor sells them. Any help would be appreciated!
  • XR4DEZ
Posted September 20, 2006 - 08:22 AM
Try BRP or use 2 sets of bottom triple clamp mounts, some tall guys use quad bars too.I don't have the problem I'm height deficient but have a 6'9" riding buddy. He uses a BRP sub mount and tall bars.
  • XRandWRRider
Posted September 20, 2006 - 08:28 AM
Try some fat bar adapters on top of the factory triple-clamp or a Scotts Under Bar (S.U.B.) Mount on a BRP/Scotts Triple clamp with Pastrana FMX or similar bend bars. That will definitely get you up where you want to be in height. The adapter + new bars will be the cheapest route at about $120, but you may need new/longer throttle cables if go too high. I have the S.U.B. with "CR High" bend which are lower than the Pastrana FMX bars, and I needed the new throttle cables. IIRC I paid about $55 for the cables. It was expensive, but worth it IMHO. The change will make it seem like a new bike. You will actually be able to stand without killing your back and/or your legs. Good luck!
  • xr650rkyle
Posted September 20, 2006 - 09:41 AM
I have an Applied triple clamp installed already so i don't need the BRP clamp.
Just need high risers with a bolt...
On BRP's web site it says that you must use their clamp with the high sub mount, So I don't think their risers will work with applied's triple clamp..
Or will They???
  • BigMikey
Posted September 20, 2006 - 01:01 PM
Not sure with the Applied clamp, but I'm 6'8" and picked up some bar risers from Thumper Racing a few years ago that are 1.5 up and 1.5 out. Using the stock clamp they work great for me. The risers aren't listed in their online catalog that I could see, but I'd drop them a line. I'm sure they could answer the Applied clamp question too.
Hope that helps...
  • tpsman
Posted September 20, 2006 - 05:01 PM
I just installed these risers...
Dirtbike Pro Risers (Move the bars up and forward about an inch each direction)
http://www.dirtbikep...uct/630-5498219
http://www.azangelma...otos/Risers.jpg
http://www.azangelma...tos/Risers2.jpg
The net effect
Stock
http://www.azangelma...os/StockBar.jpg
New and improved
http://www.azangelma...hotos/HiBar.jpg
  • xr650rkyle
Posted September 23, 2006 - 09:23 AM
The dirt bike pro adapters look like a cheap way to go, I might give them a shot. PS: I called thumper racing and they make an adapter mount that moves it up and out 1.5" but only comes in 7/8" size. I wish they had one for a 1 1/8...
  • 767driver
Posted September 23, 2006 - 07:11 PM
Tag metals also makes a riser(big bar). I put one on one of my R's. Got it from Afterburnermx.
  • 7 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  158 replies
  • Hot  28 replies
Honda XR650L 2016
  • 0 reviews
  • 2 replies
