any one use a Dial-A-JEt
3 replies to this topic
  • slammmin72
Posted September 19, 2006 - 08:55 PM
i just found out about this product, its an exteranl jetting kit, some guy recomended it to me beause when we get up inot the higher altitudes the bikes start having problems with the mixture. the company claims that u can rejet a bike in about 2 mins. its soley ment for altitude adjustments, aftermarcket pipes, modded arboxes, and htat sorta stuff. so if any one has one of these on their 99-02 YZ426 please let me know how it works. thanks again
Here is their website:
http://www.thunderpr.../dial_a_jet.htm
  • Way Fast Whitey
Posted September 20, 2006 - 06:14 AM
dail a jet is for harleys and sleds. not used on dirt bikes.
its really too bad i couldn't rig up a Tempa-Flow or ATTACC onto these bikes. they work wonders on sleds, well worth the $200 for the Tempa-Flow, never tried the $400(???) ATTACC.
  • StreetbikePimp
Posted September 20, 2006 - 09:22 AM
For quick altidute adjustments, the only jets you would need to change would be the pilot jet and the main jet. Both of which can be changed in about 5 minutes without removing the carb from your bike.
Posted September 20, 2006 - 09:33 AM
It's not quite that simple on the '06.
  • Hot  50 replies
  • Hot  36 replies
  • Hot  47 replies
