what is the best clutches for the 04 yz 450
7 replies to this topic
  • dwnlowx
Posted September 19, 2006 - 12:06 PM
i just recently purchased all hinson clutch components and was wondering what type of clutches to run barnett ,yamaha, anything else out there i need some tips here from experince with blowing clutches out and what grabs best
thanks
  • Ga426owner
Posted September 19, 2006 - 12:14 PM
thanks
I assume you bought pp, hubs and basket from Hinson....So did I and I use GYTR clutch plates...it works awesome :thumbsup:
  • 02YZ426
Posted September 19, 2006 - 02:34 PM
I will second the GYTR clutch plates.... They work great.
Posted September 19, 2006 - 02:39 PM
Hinson, GYT-R, or OEM. Use Hinson or GYT-R springs, also.
  • PK
Posted September 19, 2006 - 03:15 PM
I've never had any problems with OEM clutches but I have had problems with other aftermarket brands. Remember to soak the plates in motor oil before you install them.
  • dwnlowx
Posted September 20, 2006 - 08:43 PM
was this set up worth the money , as in all hinson comp,
Posted September 21, 2006 - 08:26 AM
As to whether it was really worth it, I don't know, but I'll tell you this. The Hinson in my '03 is without question the smoothest, toughest, best working clutch I've ever had in any dirt bike I've ever owned in 40 years. I run high overall gearing, and have to use the clutch a lot in the few really tight places I ride. It could care less, it seems. It never slips, grabs, fails to release, or needs more than two fingers to operate it, and it's been like that for 3 years. Worth it?
Those interested can save some money by going with GYT-R hardware. It used to actually be re-labeled Hinson parts, but I hear that's changed. As far as I know, the quality is still there.
  • Ga426owner
Posted September 21, 2006 - 08:34 AM
agreed it is definitely worth the money....over stock clutch components
  • Hot  50 replies
  • 0 replies
  • Hot  47 replies
  • Hot  36 replies
