Bigger Front Sprocket
5 replies to this topic
  • jcorni
Posted September 16, 2006 - 10:22 AM
I am putting on a 15 tooth front sprocket on a 06 WR 450, and the case save will not go on it hits the chain .Does someone have advice on the proper way to install. thanks :thumbsup:
  • Alley Cat
Posted September 16, 2006 - 11:19 AM
15 tooth fits on my bike with the stock case saver.
You might have to take a bit of material off the case saver to fit it, but I never had to.
Try installing the sprocket first then the chain with the case saver in place.
  • steve lemley
Posted September 16, 2006 - 07:16 PM
You have to slide the gear in at an angle twords the center of the chain guide then push it on to the tranny side gear. There should be a groove in the middle of your chain slider forthis to happen, if not buy a better one or take it off and knotch it with a grinder...
  • jcorni
Posted September 17, 2006 - 11:15 AM
Hey guy,s,I got it, thanks for the help.I think I was a little tired at the time I was installing,came out the next morning and it went wright on. :thumbsup:
  • Beejay
Posted September 18, 2006 - 04:01 PM
Hehe, a clear mind can do wonders :lame:
  • uncleroby
Posted September 19, 2006 - 01:24 AM
I have mounted the 15 and the bike goes much better!
